headlight always on??
  • polkat
  • polkat's Avatar Topic Author
22 Oct 2009 20:31
#329071
My 1982 KZ750-4 has the headlight on any time I turn the key on. It also has the reserve lighting device. On another forum a poster wrote that the reserve lighting device, aside from changing the beam if one goes out, is also designed to turn on the headlight after the engine is running.
Really? I have the reserve lighting device in my '82 KZ750-4, but the headlight is always on when I turn the key on, before starting the engine. Before now I thought that was normal, but, should the headlight actually be off until after the engine starts? And if so, is it a bad reserve device??
  • timebomb33
  • timebomb33's Avatar
Re: headlight always on??
22 Oct 2009 20:48
#329074
correct me if i'm wrong but i think from 78 or 80 i'm not sure which the bikes are designed to have the headlight on whenever the igntion switch is turned on do you have a headlight shut off switch on your bike. the reserve light device is designed to switch the elements in case one blows.
I THINK MY POWERBAND BROKE
  • bountyhunter
  • bountyhunter's Avatar
22 Oct 2009 21:43 - 22 Oct 2009 21:43
#329083
My '79 has the key on lights on (no switch).
Last edit: 22 Oct 2009 21:43 by bountyhunter.
  • vintagestyle7
  • vintagestyle7's Avatar
22 Oct 2009 22:29
#329087
My 79 controls has a headling On/Off switch and my 81 controls has a spot for it with no actual control. The low beam comes on when the ignition is turned on.
HTH
Brian
1979 KZ650 B
1975 CB500 T
  • Bluemeanie
  • Bluemeanie's Avatar
23 Oct 2009 05:52
#329104
Same with my '80. There is a place with "on" and "off" but it's plugged. Lights on for safety!! :)
  • Locozuna
  • Locozuna's Avatar
23 Oct 2009 06:17
#329108
Isn't there a cutout so that when the starter is engaged the headlight cuts out to deliver more power to starting?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • bountyhunter
25 Oct 2009 13:54
#329546
No, but I added one to mine after it ate the first two batteries in about 12 months each.:angry:
Now the batteries last about 5 years or more.
  • JR
  • JR's Avatar
25 Oct 2009 18:15
#329612
On my 1980 KZ750/4 the headlight is also on once I turn on the ignition.
I had'nt heard of a reserve lighting device. :huh: I wonder if I have one. How would I know ?
  • KYKZ1100
  • KYKZ1100's Avatar
25 Oct 2009 20:07
#329650
Bountyhunter, How did you install the cutout? Is it a manual switch or does it turn the headlight off automatically when the starter is engaged?
1981 KZ1100A1 Shaft
2007 BMW R1200R
  • bill_wilcox100
  • bill_wilcox100's Avatar
25 Oct 2009 20:58 - 25 Oct 2009 21:06
#329658
I thought it was kind of dumb to have the Headlight ON while I was trying to start the engine. :dry:
For that reason I added a relay to disconnect the power to the Headlight whenever I press the Start button. Works fine for me. B)
See the circuit I used:
For more electrical mods I've done see here:
Photobucket
Hope you find some of these useful.
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 25 Oct 2009 21:06 by bill_wilcox100.
  • polkat
27 Oct 2009 01:12 - 27 Oct 2009 01:23
#329882
JR, I don't think that the reserve device started until '81 or '82. My '83 has it. It's an interesting idea, but in my opinion, just another item and more wiring to go bad. Most of us can tell pretty quick when a headlight filiment burns out.
Seems the simplest way to do it is run the blue wire that feeds the hi/lo switch through the closed terminals of a relay. Then tap into the black wire that runs from the starter button to the selonoid. Run this wire into the relay coil and run the other side to ground. Every time you hit the starter button, the headlight will shut off until you release it and the relay coil shouldn't draw anywhere near as much as the headlight does.
With the headlight on, starting places the strongest draw on the battery, and this should ease it considerable.
This may be in fact what Bill is showing, and sorry Bill if it is, but the pic is a little fuzzy on my computer.
Last edit: 27 Oct 2009 01:23 by polkat.
  • bountyhunter
27 Oct 2009 11:27 - 27 Oct 2009 11:32
#329938
Automatic. I got a pair of normally closed 10A relays and installed them in each line coming off the two 8A fuses that serve nearly all the electrics on the bike (except the ignition coils). I use the 12V feed to the starter solenoid to drive the relay coils so that the normally closed contacts feeding the bikes lights open anytime the starter engages. That cuts off not only the headlights but also the tail light/running lights and speedo lights when startingb which is about another 50W total.
Last edit: 27 Oct 2009 11:32 by bountyhunter.
