Stator housing and oil
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar Topic Author
20 Mar 2006 12:56
#32847
I'm assuming it's ok for the inside of the stator cover to be full of oil? Should it be full or should it have just a dribble? Why does it need oil in there?
Thanks.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: Stator housing and oil
20 Mar 2006 15:17
#32883
To lube starter gear. There should be a small passage going into the engine if you look under the alternator.
  • wiredgeorge
  • wiredgeorge's Avatar
21 Mar 2006 06:48
#33041
Actually, the reason oil is in your stator cover is that Kawasaki put the oil journal in there so that oil would slowly leak out the plug where the wires pass through. This is sort of a "fail safe" method of ensuring engine oil is changed as you will continually need to top off your oil with fresh oil to keep the sump full. The "leaky rubber plug" engine oil replacment method is only one of the ways, Kawasaki engineers were thinking about you when they did their careful design of the early KZ engine!
  • donthekawguy
  • donthekawguy's Avatar
21 Mar 2006 18:21
#33205
I always thought it leaked to keep your boot lubed so shifting was easier! :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
