Dyna S rpm gauge not working
- KZ1100 Bully
16 Oct 2009 06:45
Hi, messing with the wires and not sure if I run both ground wires from the coils or just one to get rpm gauge to work right?
Thanks
Thanks
1983 Kawasaki KZ1100 Spectre D2
- Old Man Rock
Re: Dyna S rpm gauge not working
16 Oct 2009 08:41 - 16 Oct 2009 08:42
"rpm gauge to work right"... :huh: ?
Other than effecting the rpm/timing itself, this has nothing to do with your tach gauge working correctly....
Not sure I'm/we're following correctly....
Yes, the Dyna needs to be wired correctly... The grounding is through the ignition plate being screwed into the casing... Engne needs proper grounding!
Maybe this will help.... Tutorial I wrote...
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 Oct 2009 08:42 by Old Man Rock.
- KZ1100 Bully
16 Oct 2009 08:48
Does the tack run off the white wire or the green wire? I have a black wire running to the tack not sure what wire join to it green or white or both.
- OnkelB
16 Oct 2009 10:13
Dave, he has an electronic tach that reads off one of the coil trigger wires, same setup on my GPz 1100.
Bully, you should only connect the black tach wire to one of the coil wires. I would think it doesn't matter which one, but if in doubt check which coil wire (1/4 or 2/3) used to black in the stock setup and connect the black tach wire to that coil. Btw, you still have the brown tach wire (+12V connected, right?
77 KZ 650 B1, 82 GPz 1100 B2.
- KZ1100 Bully
16 Oct 2009 10:27
Yes I think I do. I also did the Wired George coil mod?
The only wire I removed was the black one. I removed the black wire installing the Dyna S, that black wire that ran to the tack it still does,I hooked the white wire with black shrink wrap to the black wire running to the tack.
Thanks guys, I will not know if it is working as the bike is stored inside
- Old Man Rock
16 Oct 2009 12:50
" he has an electronic tach that reads off one of the coil trigger wires"...
Same here with my Acewell Speedo/Tach unit.
So this is actually a "Dyna S rpm gauge "...
Meaning a RPM display unit?
If so, Whoa, didn't know they made gauges.... Learn something new everyday... cool!
Sorry for my confusion...
Thanks for the update...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- OnkelB
16 Oct 2009 13:05
No, he's trying to make his stock electronic tach work with a Dyna S, at least that's how I read it.
I just installed an Acewell 2802 (same as yours) on my GPz 1100 that also has a stock electronic tach - Acewell suggest you wrap the tach sensor wire around one of the plug wires, but I found it was a better solution to connect it directly to one of the coil trigger wires, works like a charm.
Bully, the coil mod won't matter as it only concerns the 12V supply to the coils, I believe connecting the tach sensor wire to either of the coil trigger wires will work.
- KZ1100 Bully
16 Oct 2009 13:29
Thanks that is what I did " to either of the coil trigger wires will work.
Thanks guys!
Thanks guys!
- Old Man Rock
16 Oct 2009 13:35
"Acewell suggest you wrap the tach sensor wire around one of the plug wires, but I found it was a better solution to connect it directly to one of the coil trigger wires, works like a charm."
In my Acewell directions, they provided both methods and recommended the direct solder to coil termiantion... Hmmm... Either way, for higher degree of pick up accuracy, direct termination is the way to go no doubt....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- OnkelB
16 Oct 2009 13:53
Dave, upon closer inspection you're right, the Acewell instructions actually shows both methods, the wrap method is shown on the front page while the direct method is shown in the diagram. Seems I missed the fine print...
Bully, no problem, only happy to help.
