dyna s installation: spark advance nut direction ?
- KZJerry
14 Oct 2009 21:35
Hey All quick question.
I am installing a dyna s ignition system in my 76 kz900 A4. I need to know the direction of the 13mm bolt and 17mm nut holding the spark advance (points cam) in place... aka is it reverse or normal threaded???
thanks if you can help.
- MFolks
Re: dyna s installation: spark advance nut direction ?
14 Oct 2009 21:54
If it's like my 82 GPz1100 it's right to tighten and left to loosen(as you look at it).
- Old Man Rock
15 Oct 2009 04:58 - 15 Oct 2009 05:44
Normal CW to tighten....
And be EXTREMELY careful with that 13mm nut....
Several members here have reported of snapping this bolt...
Snug is good where no real hard torque is required!
OMR
EDIT:
Follow the link... Tutorial for Dyna-S on KZ900-A4...
Maybe will help....
NOTE: I have performance cams @ 105 lobe centers so final mark alignments may differ from yours but the procedure is the same....
Example: Static is to advance timing marks but on mine, F mark is what was required then dynamic came out correctly....
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
OMR
OMR
EDIT:
Maybe will help....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 15 Oct 2009 05:44 by Old Man Rock.
15 Oct 2009 05:31 - 15 Oct 2009 05:35
The 17mm "fake" nut isn't "threaded." It fits into position where it's designed to also provide a grip for a wrench to hand-rotate the crankshaft.
Good Luck!
Good Luck!
Last edit: 15 Oct 2009 05:35 by Patton.
- trianglelaguna
15 Oct 2009 07:26
spray it ...give it a soft direct tap with a wrench or tiny hammer...and loosen in the normal direction....the 13 is the one to loosen....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- timebomb33
15 Oct 2009 08:46
righty tighty, lefty loosey
I THINK MY POWERBAND BROKE
- KZJerry
15 Oct 2009 11:32
Thanks for the replies, I will be extra careful with that 13mm...thats the reason I initially posted this, because it was not coming off normally and I didn't want to force it and break the bolt...That has already happened with some bolts on my 900, and this one seems extra-inconvenient to repair.
15 Oct 2009 12:22 - 15 Oct 2009 12:23
trianglelaguna wrote:
Yes. PBBlaster or Kroil is imo the best spray, and would allow it to soak at least overnight.
An air or electric impact wrench might also help jar it loose.
Good Luck!
Good Luck!
Last edit: 15 Oct 2009 12:23 by Patton.
- netcats
17 Oct 2009 09:57
Hello,
Just did mine the other day, loosen counter clockwise.
When you tighten it up torque setting is 16.5 - 19.5 foot pounds, as per Kawasaki manual, I used 18 for mine and it works.
Hope this helps.
Regards, netcats
Hope this helps.
Regards, netcats
- Bluemeanie
17 Oct 2009 19:51
Old Man Rock wrote:
I've never snapped the 13mm bolt but I DID shear off the dowel pin! Try and drill that hardened bitch out! :woohoo:
OMR
- Old Man Rock
18 Oct 2009 13:13
"Try and drill that hardened bitch out!"...
:laugh: :laugh: :laugh:
Before everyone gets there panties in a bind.... I'm laughing at the way you wrote it not in the fact of the matter....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
