Igniter Question
- Andrew231989
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Thank you received: 2098
I own a 1981 kz 440 d1 twin. I was wondering if anybody knows an electronic ignition kit for this or a replacement ignition module that will work. Much apprciated is the help. ( i am very tired of paying 400+ dollars for such a unit. but if aftermarket i would consider it.
Hello, Andrew, and WELCOME to KZR!
We're glad you're here!
Click > Here
Then scroll down to the post by loudhvx and click on the link provided.
Good Luck!
- loudhvx
- Thank you received: 1616
www.geocities.com/loudgpz/GPZgmHEImod.html
If you scroll all the way down you'll see the kz twin's version.
I'll post the diagram here in case it's gone from the server.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- JR
- Thank you received: 447
That geocities server is closing this month so it may not be up for long.
quote]
I'm glad I saved a copy of the diagrams and photos on my hard drive. Never know when I might need this info.
- Andrew231989
- Andrew231989
- Andrew231989
it had a bad ground circuit fault once it was hot. then it would die and have to cool before it would work again.what is wrong with your stock one.
i am going to try that gm module just because i can justify 5 benjamins :ohmy: for a transistor circuit.
- Andrew231989
JUST So happens i found a good one in a parts bin of mine.
WAHOOOOOO its running again. :laugh:
- MFolks
- Thank you received: 540
