Headlight only works on high-beam (77 KZ1000)
- oberkfell
03 Oct 2009 13:53 #325264
by oberkfell
1977 KZ1000-A
Headlight only works on high-beam (77 KZ1000) was created by oberkfell
I was having problems with my LH control pod after I replaced my handlebars.
Everytime I would flip from High to Low beams a fuse would pop.
In addition, the low beam would and/still does not stay on after startup & revving up the motor. But, the High Beam stays on and does not dim when revving the bike.
I replaced the LH control pod and it fixed the fuse issue, as I assume it was a pinched wire.
I cleaned all the connectors throughout the electrical system and made sure all the wires matchup. I had new plugs, points, condensor, etc. also replaced. The battery is fully charged.
I took the RH control pod off and inspected it, but did not see any damage to the wires.
Any ideas? Rectifier/Alternator/Stator?
1977 KZ1000-A
- bountyhunter
- Thank you received: 337
03 Oct 2009 14:30 - 03 Oct 2009 14:31 #325267
by bountyhunter
Replied by bountyhunter on topic Headlight only works on high-beam (77 KZ1000)
Low beam works when cold but not after warm up?
This:
makes me ask a dumb question: is it possible the low beam lamp is just bad?
This:
Last edit: 03 Oct 2009 14:31 by bountyhunter.
- oberkfell
03 Oct 2009 15:26 #325272
by oberkfell
1977 KZ1000-A
Replied by oberkfell on topic Headlight only works on high-beam (77 KZ1000)
I took it out for a test ride.
Low beam seemed to work the entire time I was riding, until I slowed down and parked it. Then it would go out. I would give it some gas and it would come back on.
This seems to be the pattern.
The High Beam works all the time.
No probs.
My old man said, "Screw it ride it with the high beams on and forget it."
Doesn't sound like a bad idea, except its pissing me off to no end trying to track down the problem.
I have not tried to put in a new lamp to see if that was the problem. I know the dillweed that sold it to me said it was new. Of course he said it was an 8 out of a 10 on craigslist. Well......with about and extra 1500 maybe a 7 now.
No probs.
1977 KZ1000-A
- chance
- Life long biker/
03 Oct 2009 17:15 #325285
by chance
Replied by chance on topic Headlight only works on high-beam (77 KZ1000)
bountyhunter wrote:
I have seen the headlight bulb elements barely touch and the light will work intermetly has the spring will vibirate. It will blow fuses doing this also . So get a good one to check that out first..Low beam works when cold but not after warm up?
This:
- MFolks
- Thank you received: 540
03 Oct 2009 17:57 #325295
by MFolks
Replied by MFolks on topic Headlight only works on high-beam (77 KZ1000)
Remove the two screws holding the headlight to the housing,put a folded towel in case the headlight drops to the front fender, and disconnect the three prong electrical connector.
The headlight bulb should have a rubber dust cover that probably needs to push and twist to remove,carefuly pull the bulb out of the headlight lens and look for broken filament(s).
- oberkfell
03 Oct 2009 20:57 - 03 Oct 2009 21:08 #325342
by oberkfell
1977 KZ1000-A
Thanks, I will try those ideas out tomorrow.
I'm a moron though, it does have a sealed lamp.
Damn, rain.
Damn, rain.
1977 KZ1000-A
Last edit: 03 Oct 2009 21:08 by oberkfell.
- oberkfell
04 Oct 2009 20:38 #325555
by oberkfell
1977 KZ1000-A
Thanks for the help. Fixed.
A simple idea of changing the headlamp fixed the problem.
This is after taking each wiring harness out as well as the control pods and cleaning them out. That took a while.
Now after getting the bike back to together and 10 minutes on the road, another recurring problem has mysteriously popped up.
Well its off to the brakes forum.
1977 KZ1000-A
