help!
- Twichel04
- Banned
01 Oct 2009 10:33 #324914
by Twichel04
help! was created by Twichel04
im not too great with wiring..
i am looking for a bare bones wiring diagram that i can use on my 84 kz550. im doing a cafe so i just want bare minimums... lights, blinkers, and stuff the run the motor. i have come across one, BUT it does not have a starter on the diagram and since the 550 doesnt have a kick start,, i need one haha
thank you in advance
this is the one that i already found on here...
- bountyhunter
- Thank you received: 337
01 Oct 2009 11:28 #324918
by bountyhunter
Replied by bountyhunter on topic help!
Wire the starter's main power lead straight to the battery through a high current (starter) solenoid. The relay terminal of the solenoid goes to the start button switch, other side of the switch goes to 12V from the ignition switch.
- loudhvx
- Thank you received: 1616
02 Oct 2009 06:22 #325004
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic help!
1981 KZ550 D1 gpz.
Other links.
