L E D lights in your speedo and tach,anyone did it
- kzrider4life
30 Sep 2009 16:39 #324807
by kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
L E D lights in your speedo and tach,anyone did it was created by kzrider4life
I am wanting to put some led's in my speedo and tach,anyone done it yet and any advice?
- MFolks
- Thank you received: 540
30 Sep 2009 18:33 #324821
by MFolks
Replied by MFolks on topic L E D lights in your speedo and tach,anyone did it
Are you talking about replacing the standard light bulbs with LED's or an installation of them to show speed and rpm's?
- kzrider4life
30 Sep 2009 18:35 #324822
by kzrider4life
Replied by kzrider4life on topic L E D lights in your speedo and tach,anyone did it
Just replacing the bulbs with green led's
- Old Man Rock
- Thank you received: 225
30 Sep 2009 19:26 - 30 Sep 2009 19:28 #324829
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic L E D lights in your speedo and tach,anyone did it
Use a 1000 ohm, 1/2 watt (can get by with a 1/4 watt but I'd go with 1/2 watt) resistor off the +12Vdc to the anode of the LED and the cathode of the LED to ground....
Should be good to go....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 30 Sep 2009 19:28 by Old Man Rock.
- Dave Sloan
- Thank you received: 3
01 Oct 2009 02:31 #324867
by Dave Sloan
Z650B2 - Injected
Replied by Dave Sloan on topic L E D lights in your speedo and tach,anyone did it
Will these use less power than the stock bulbs?
Z650B2 - Injected
- AtLarge
- Thank you received: 21
01 Oct 2009 04:49 #324871
by AtLarge
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
Replied by AtLarge on topic L E D lights in your speedo and tach,anyone did it
Power consumption and heat are both reduced. I swapped out all of mine including the turn signals (4w). I used the ones from Superbrightled's. The only ones that didn't work are the turn indicators in the dash because they use a shared line and the led's (diodes) are directional and would require extra wiring. Make sure you get the wide ones for the gauge face so it spreads out more. Nice deep dark green now. Looks good. I used the high intensity on the oil, neutral and high beam.
1973 Honda CL70-K3
1994 BMW K1100RS
- kzrider4life
01 Oct 2009 06:11 #324875
by kzrider4life
I wonder if orange would lite up orange.
- hugo
- '92 Zephyr 750
- Thank you received: 70
01 Oct 2009 07:55 - 01 Oct 2009 07:59 #324888
by hugo
Replied by hugo on topic L E D lights in your speedo and tach,anyone did it
I believe you are asking only for Speedo and Tach ilumination. This is very hard to do with LEDs because they don't radiate nor flood light around the way incandescents do.
I tried hi intensity LEDs for ilumination on my Tach and Speedo, and the effect was dimmer than incandescent so I went back to stock bulbs. I'd still like to try if I could find more appropriate 'radiating' type.
For spot indicators like oil, neutral, hi-beam etc, no problem, as long as you use high intensity and same color as lense. They are not cheap.
I believe in changing to LED's if possible because they are far more efficient, as don't dissipate heat, and lack of filament makes them more reliable.
Last edit: 01 Oct 2009 07:59 by hugo.
