huge 2X spark plug gap needed for CDI? WHY?
  • newOld_kz1000
  • newOld_kz1000's Avatar Topic Author
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
29 Sep 2009 21:49 - 29 Sep 2009 21:50
#324722
I have a Gerex electronic ignition, kz1000 1978, and the install manual says:
"Re-gap plugs to .063" - .065"
which in metric is: 1.6mm - 1.65mm.
Meanwhile, the kz1000 factory shop manual calls for a spark plug gap of:
0.7mm to 0.8mm.
Wow man. Big difference!
Funny thing too, because the Gerex install manual says this in the same section:
"Don't attempt to draw a long spark from spark plug! Your ignition coil may be destroyed."
It's like "Excuse me, you just told me to double the normal plug gap then you say 'don't draw a long spark' ??
Any ideas on why this or any Electronic Ignition (CDI) would require a double-large plug gap?
And why then say 'don't draw a long spark' ??
Is this huge a plug gap needed for CDI electronic ignitions? Or should I just stick with the stock plug gap of .7mm - .8mm ??
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 29 Sep 2009 21:50 by newOld_kz1000.
  • bountyhunter
  • bountyhunter's Avatar
Re: huge 2X spark plug gap needed for CDI? WHY?
29 Sep 2009 22:38
#324725
0.7mm to 0.8mm.
Sounds like baloney to me. I have run an aftermarket CDI on my 1979 KZ-750 for 28 years. Use the stock plug gap. You probably can open the gap up a LITTLE and still run OK because the CDI can put out a little more spark voltage. I see no advantage to doing that.
  • bountyhunter
29 Sep 2009 22:42 - 29 Sep 2009 22:47
#324726
0.7mm to 0.8mm.
There is a grain of truth there in the warning. A coil's windings are designed to handle a certain amount of voltage. A CDI ignition has the ability to produce more voltage across the coil which can potentially damage it. Worst case is when you draw the longest spark possible since it is firing at the highest potential the ignition can force across the coil, which is probably 2X stock voltage. Stock coils really aren't designed to handle CDI, but most do for a long time. I ran my stock coil about 20 years before it failed, and it may just have died of old age related disease.:laugh:
You are correct that doubling the plug gap will double the coil secondary voltage when the plug fires which doubles the voltage stress on the secondary winding, which will shorten it's life. I would not do it because it doesn't increase performance.
Last edit: 29 Sep 2009 22:47 by bountyhunter.
  • JamesD
  • JamesD's Avatar
29 Sep 2009 23:30
#324727
Take a look at small block chevy's. For years there was a fairly consistent plug gap. Then the HEI came along, with the integral coil, and also a much higher spark plug gap. What warranted that? Could it be a similar technology?
I know with older two strokes, the CDI bikes used a different coil vs. the points bikes. Not sure why, but the above posts make sense.
  • loudhvx
  • loudhvx's Avatar
30 Sep 2009 09:12 - 30 Sep 2009 09:15
#324772
HEI works on the same principle as standard Kettering style points ignitions. It just uses a transistor instead of points, and some Zener diodes for protection while doing away with the condenser.
CDI uses a very short duration pulse but is capable of producing higher secondary peak voltage before the spark arcs (as Bountyhunter said). What they mean by "don't draw a long spark" is probably don't draw a long DURATION spark. Meaning time, not distance. Or possibly they mean to not draw a long (distance) spark longer than what they prescribe.
They are probably telling you to widen the gap in an effort to compensate for the short duration. More spark area ignites a larger flame kernel, same effect as a longer duration spark. If a small kernel spreads quickly, a larger kernel is not needed. While this may be necessary on some motors, a KZ in good condition probably does not need it and won't benefit from it. Keep the gap stock until you know you need to widen it. If it idles smoothly and revs all the way to redline smoothly, I wouldn't worry about it.
As mentioned, a wider gap will shorten the coil's life expectancy.
Last edit: 30 Sep 2009 09:15 by loudhvx.
  • bountyhunter
30 Sep 2009 13:42 - 30 Sep 2009 13:48
#324793
Something to think about: when the points open, the voltage builds up on the primary winding and couples across to the secondary winding (spark plug side). It increases until the voltage is high enough to jump the plug's air gap and then the coil's energy gets dumped. This means when the plug fires it acts as a clamp to limit the coil's secondary voltage.
Most data shows that a standard points ignition can muster about 25kV or maybe 30kV on a good day, and a good CDI can kick 50kV - 60kV. This is OPEN CIRCUIT voltage, since the spark will clamp it at a much lower voltage in actual operation (I think the plug fires at maybe 5kV ballpark?).
What people don't remember is if you foul a plug so it won't fire, then the ignition does build up to the open circuit voltage which means a CDI is putting the full 60kV onto the coil's secondary winding until that plug clears and starts firing. That is actually more stessful to the coil than running "wide gap plugs" IMHO.
I don't think running wider plugs will increase performance in a KZ. There has been a ton of internet information and BS recently about spark energy and duration because of the new "super duper" plugs with the eaxtra hot spark but I have never seen any credible evidence they do anything. The published dyno tests show "increases" of maybe 0.3% which is actually within the measurement error of the tests.
I always say the same thing: bike makers are dying to get a couple of extra horses out of their engines. If a new plug or ignition technology would do it, why aren't they using that?
The aftermarket ignitions like Dyna increase performance because they can tailor the spark advance curve to the engine and also because their output does not drop off at high RPM. They do increase performance a little but you wuld need a dyno to see it.
I use an aftermarket CDI with original points (which was state of the art 28 years ago when I got it) and it has the advantages of:
1) Points last forever because they only have low voltage on them.
2) Hotter spark when cold cranking.
3) More spark reserve to fire a reluctant plug.
It runs very well and I never have to buy points or condensers.
Last edit: 30 Sep 2009 13:48 by bountyhunter.
  • newOld_kz1000
01 Oct 2009 20:37
#324972
Excellent -- great info. I have a bkgnd in electronics and while the conceptual underpinnings of a bike's electricals and ignition system are pretty basic -- I've never had the ignition part of it regarding the primary and secondary coil windings and especially the 'clamping' effect of the plug -- explained so clearly -- thanks. Thanks also to Loudhvx for the clarity on the 'drawing a long spark' issue.
Based on everyone's feedback, I'm leaving the stock plug gap for now and will adjust if I need to -- the old plugs had the stock gap and the prior owner said the bike ran great.
  • TurboLTD1000
  • TurboLTD1000's Avatar
07 May 2026 12:36
#923758
I recently bought a 1977 KZ1000 with a turbo and a Gerex ignition with coils and spark plug wires. The owner's son I bought it from said his dad has dementia. So when I pulled the new plugs he put in, I thought the gap was set at .067" due to the dementia until I saw your post last night. I got it started after sitting for forty years, but not easily. I regapped the plugs to .038" this morning and it started much easier and ran better. I'm just sayin.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 May 2026 15:04 - 07 May 2026 15:09
#923762
Most of the content in this thread is interesting but not particularly accurate !! in simple terms when the points are closed a constant current flows in the primary winding (usually around 3-4 amps) which generates an electro-magnetic field. The primary winding is wound around a laminated iron core which amplifies the magnetic field. The secondary winding is wound around the primary winding but there is no physical connection, when the points open the magnetic field collapses which causes a voltage to be "induced" into the secondary winding (the HT voltage is determined by the ratio of windings in the primary and secondary coils) hence a "high output" coil will have a higher winding ratio and lower resistance in the primary so the current flow is greater.
Increasing the gap will potentially give a bigger spark however don't forget electricity is lazy so it will look for an easier path to ground (poor insulation on the HT leads, dirt build up on the plugs etc) Also the higher the cylinder pressure the harder it is for the spark to jump so in your case when the turbo comes on boost it's likely to cause a high rev misfire. Play safe and stick to factory gaps is my advice.
The relationship between magnetism and electricity is how your generator works and why regular 4 pin 12v relays can generate a momentary "back voltage" in excess of 300v when switched off !!!
Last edit: 07 May 2026 15:09 by Wookie58.
The following user(s) said Thank You: Warren3200gt
  • Nerdy
  • Nerdy's Avatar
07 May 2026 17:46 - 07 May 2026 17:48
#923767
Please check the dates on messages before you reply: this thread has been dormant since 2009 :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 07 May 2026 17:48 by Nerdy.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 May 2026 00:47
#923773
It is indeed an old thread but as the new guy was using it for reference it seemed prudent to correct the mis-information contained therein :)
The following user(s) said Thank You: StreetfighterKz, F64
  • Nerdy
  • Nerdy's Avatar
08 May 2026 18:25
#923784
That's more than fair, of course, but at the same time it's not great to have new people replying to others who are no longer on KZR and won't respond :)
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
