speedometer woes
  • epop2357
  • epop2357's Avatar Topic Author
speedometer woes
21 Oct 2005 10:58
#3246
I have a '77 KZ900. I was going down the road and the speedometer quit. Headed home to change the cable and found there was nothing wrong with the cable on the bike. What are the easiest ways to find out if the problem is with the speedometer or the sender at the wheel? Speedometers seem really rare and expensive. Can they be repaired and are parts still available? Any help will be greatly appreciated.
Post edited by: epop2357, at: 2005/10/21 14:00
Post edited by: epop2357, at: 2005/10/21 14:02
  • rivieracadman
  • rivieracadman's Avatar
Re: speedometer woes
21 Oct 2005 12:10
#3260
Throw it on the ground, stomp a few times heavily, and walk back to the computer and check on e-bay. :) Honestly a bone yard or E-bay would be your best option, if your trying to keep the bike looking origional. Otherwise there are generic aftermarket speedos that work much better, and seem to be more accurate.
  • JR
  • JR's Avatar
21 Oct 2005 12:11
#3262
Can you put the bike on a centrestand, put a weight on the rear seat so the front wheel is off the ground and spin the wheel to see if the cable turns?
  • epop2357
21 Oct 2005 12:29
#3265
No centerstand, but I do have a floor jack. Thanks a lot....
  • luvmykaw
  • luvmykaw's Avatar
21 Oct 2005 12:31
#3266
If everything checks out and you trace it back to a hinky speedo, WiredGeorge did a write up about repairing either a speedo or tach. It's somewere in the old Archives.
  • epop2357
21 Oct 2005 12:31
#3268
thanks man, that was my first thought, but then thought I might try to keep it semi original. I have some Honda CB750 scabs at my son's house. Maybe one of them will work.
  • epop2357
21 Oct 2005 12:33
#3269
thanks luvmykaw, I'll look that up.
  • Spock
  • Spock's Avatar
21 Oct 2005 15:41
#3298
My 81 KZ-1000 CSR has Honda Gages The RPMs and the MPH matches the KAW gages on my 82 KZ-1000.
I like the Honda Tack better because it has a Volt Meter.
Spock
  • duncan
  • duncan's Avatar
21 Oct 2005 16:11
#3307
there's two used speedo/tach combos for sale here:
www.oldkawman.com/
click on "KZ 900 and KZ1000 parts"
(sorry, just double checked and they're both 1980 gauges)
Post edited by: duncan, at: 2005/10/21 19:39
  • kztee
  • kztee's Avatar
  • TeeRoy
01 Nov 2005 17:15
#5994
You should check with this guy... Bob Harrington Z-Resto <76kz900@bellsouth.net>. He told me he could fix mine by replacing the drive unit for around $120... worth it if you want to keep the bike original.
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • RonKZ650
  • RonKZ650's Avatar
01 Nov 2005 18:57
#6016
Don't know what to tell you exactly, but you can easily see if the cable is turning by unhooking it from the bottom of the speedometer and pushing your motorcyle a few feet while looking at the cable to see if it turns. Chance of speedometer failure very slim, chance of drive failure very slim. Got to be something though if you're sure the cable is good. Strange.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
01 Nov 2005 19:01
#6017
Welcome epop. Your bike looks too nice as it is to build a chopper. Please don't change it, at least not drasticly.:unsure:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
