76 KZ900 A4 Instrument Panel Compatibility
- Summerheat
- Wanted at 17 Got it at 47 Worth The Wait!
28 Sep 2009 05:31 - 28 Sep 2009 05:31 #324434
by Summerheat
1976 KZ900-A4
76 KZ900 A4 Instrument Panel Compatibility was created by Summerheat
the metal bracket holding my speedo & tach has broken for about the 3rd time. Ol Mr. JB Weld is running out of surface material .
Is the metal removable from the instrument panel itslef?
And if not can I get some input as to compatible years for hot swappable idiot panel with good metal.
Thanks
Thanks
1976 KZ900-A4
Last edit: 28 Sep 2009 05:31 by Summerheat.
- chance
- Life long biker/
28 Sep 2009 05:33 #324435
by chance
Replied by chance on topic 76 KZ900 A4 Instrument Panel Compatibility
Yes the metal brk, can be removed and WELDED ..
- PLUMMEN
- Thank you received: 104
28 Sep 2009 17:33 #324521
by PLUMMEN
Replied by PLUMMEN on topic 76 KZ900 A4 Instrument Panel Compatibility
76kz-80kz/ltd should be same,im pretty sure 650,750,900/1000 use same part
- trianglelaguna
- Thank you received: 235
28 Sep 2009 18:25 #324528
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 76 KZ900 A4 Instrument Panel Compatibility
i ended up getting a few sets over the last three years from e-bay...the years that fit our 76 are 76 through 78 and the parts are all swap easy...z1 inner bracket is dif i think...any ways i would watch sets of complete speedo and tach and keyed ignitions....and some would not get bid on...35-45 is what i got em for and now will be set for my life if i break mine......i think z1enterprises sells just the brackett and i looked but did not see it.....you can swap it in an hour....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
- Summerheat
29 Sep 2009 06:54 #324586
by Summerheat
1976 KZ900-A4
Replied by Summerheat on topic 76 KZ900 A4 Instrument Panel Compatibility
Thanks for the input guys.
Trianglelaguna, sounds like you have been through this a few times so to you and Plummen...... Will the 750 bracket work? cgi.ebay.com/ebaymotors/Gauge-Mount-1976...ksid=p4506.m20.l1116
1976 KZ900-A4
- PLUMMEN
29 Sep 2009 07:11 #324592
by PLUMMEN
looks same to me,bracket on 79-80 should be same also.
