Ground wire from battery to frame?
  • barquirt
  • barquirt's Avatar Topic Author
26 Sep 2009 19:30
#324163
For rookie electricians ... can you run a wire from the battery negative terminal to the frame as a ground for your bike? I realize there is a ground in the harness somewhere but could you rig a ground wire this way as backup or insurance against electrical gremlins on a 30+ year old bike? I have a 1977 KZ650 with separate rectifier and regulator.
  • MFolks
  • MFolks's Avatar
Re: Ground wire from battery to frame?
26 Sep 2009 19:43
#324166
I believe most Negative(-) grounded bikes have/had the battery terminal on one end an usually an engine mounting bolt on the other. If you think yours is failing, go to a welding supply store and purchase some 6 gauge welding cable. It comes in two colors RED and BLACK. I think they sell it by the foot.
I'd also suggest upgrading your Positive (+) connections too as they need to have the same size conductors as the Negative one will be.
If they can't crimp/swage on the terminal lugs you need, try a battery shop as they have the special tools.
26 Sep 2009 19:48
#324167
Actually, the 1977 KZ650c came with a ground wire from the negative battery post to ground (on the rear right side of engine). This wire also has a smaller diameter lead that goes to the wiring harness. See wiring diagram for details:
KZ650C1 Wiring
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
26 Sep 2009 21:07
#324184
yea the frame will work if you can find a good location that aint getting wet and muddy.
The engine is a good place too...
Red wire is +
Black wire is -
Usually that is. ;)
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • timebomb33
  • timebomb33's Avatar
26 Sep 2009 21:12
#324187
the engine cases themselves give the best grounding point for engine related things (ignition mostly) the frame is a good ground source for pretty much every thing else i like to keep the two seperate if possible no reason other than i have always done it that way.
I THINK MY POWERBAND BROKE
