parts compatability?
- kylevk
23 Sep 2009 13:10
i've got an 82 kz750 ltd (inline 4) and it came without wiring/lights/ pretty much anything electrical....theres a 77 kz650 posted on craigslist near me for cheap, i was wondering if any parts off the 650 would be compatable with mine...any help would be appreciated!
- loudhvx
Re: parts compatability?
23 Sep 2009 15:57
Pretty much nothing significant will be compatible.
Not the alternator.
Not the regulator.
Not the rectifier.
Not the ignition coils.
Not the points/igniter.
Not the harness.
Probably not the ignition switch.
Maybe a fuse or two might be able to swap over.
Not the alternator.
Not the regulator.
Not the rectifier.
Not the harness.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- JMKZHI
23 Sep 2009 17:20
The best matches for your bike are the 81-83 KZ750-Ltd-4. The 80 model should be good too. Depending upon what's needed the 81-82 KZ750-E-Standard & 81-83 KZ650-CSR would be next in line. The electrics on the E are probably nearly identical. The CSR shares some ignition parts etc & has the same exhaust system & body parts.
