Does it matter?
- john8
- Anything unrelated to elephants is irrelephant
22 Sep 2009 21:06 #323416
by john8
I want to ride my bicycle!!!
Does it matter? was created by john8
I went to change a fuse in my 81 kz1000J before I looked at the wiring diagram. There was a 20 amp fuse so naturally I went to the store and bought 20 amp fuses. I was looking over the diagram tonight and found that there is suposed to be a 10 amp in that place. Soooo, does it matter??
- 550A2
- keep the shiny side up
- Thank you received: 1
22 Sep 2009 21:14 - 22 Sep 2009 21:16 #323419
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic Does it matter?
it wont effect anything, but the fuse is made to break if to many amps for some reason are being pushed through that circut.....
If you have too many amps being pushed through a circut that is ment to use only 10 amps you can damage wires, electrical components, ect.
I would put a 10 amp in it, if it blows it then you got a short or a bad connection somewhere.
Last edit: 22 Sep 2009 21:16 by 550A2.
- bountyhunter
- Thank you received: 337
22 Sep 2009 22:21 #323432
by bountyhunter
Replied by bountyhunter on topic Does it matter?
john8 wrote:
Not unless theres an electrical problem where you need the fuse to blow to keep the wiring from catching fire.I went to change a fuse in my 81 kz1000J before I looked at the wiring diagram. There was a 20 amp fuse so naturally I went to the store and bought 20 amp fuses. I was looking over the diagram tonight and found that there is suposed to be a 10 amp in that place. Soooo, does it matter??
