No Spark
- rayellis
No Spark
22 Sep 2009 07:15
Hey guys I have put my KZ750 back together and was going to see if I could get bike to start. I have not been able to get a spark on any of the plugs.
I do not have keys (yet) so I have been jumping the solenoid off. My question is is there something else I need to do to get spark? Has anyone jumped solenoid and started bike?
I'm testing electrical today ;so I appreciate any help!
Thank You
Ray
:woohoo: :woohoo:
Thank You
Ray
:woohoo: :woohoo:
Re: No Spark
22 Sep 2009 08:03
rayellis wrote:
Is battery voltage reaching ignition coils?
Good Luck!
Thank You
Ray
:woohoo: :woohoo:
Good Luck!
- Kawickrice
Re: No Spark
22 Sep 2009 08:04
With out the ignition on jumping from the solenoid is like kick starting with the kill button in the off position. You can make a jumper wire at the plug where the key switch plugs in if you do not have a key
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- rayellis
Re: No Spark
22 Sep 2009 10:18
Thanks, that is what I was thinking. I did not know if ignition switch would control that but I was think it might. I will give it a try before testing coils,ignitor and other electrical componets.
- rayellis
Re: No Spark
22 Sep 2009 17:38 - 22 Sep 2009 17:52
Hey that worked great I had spark on three of the wires but one was not getting fire ;so I removed the boot and checked it. Come to find it was missing this little fuse looking connector ;so since it was not making contact no fire.
Do I need the fuse that's in the boot? I have made another out of some car wires/boot. This just to get it started I will get another wire ASAP.
Thank You
Ray
Thank You
Ray
Last edit: 22 Sep 2009 17:52 by rayellis.
- Old Man Rock
Re: No Spark
22 Sep 2009 18:00 - 22 Sep 2009 18:00
As mentioned..."jumping the solenoid " ain't worth a damn... Ok, so the starter motor rotates...:blink: but outside of that, not sure what this accomplishes.
The ignition switch is what passes the +12Vdc throughout the system especially passing desired voltages to the ignition coils and back to the battery for charging....
To check your coils/plug spark etc.... Jumper from the battery to the output side of the ignition switch then test for +12Vdc on primary coil windings...
If +12Vdc still missing, check the kill switch....
OMR
Let me see if I can find a schematic... What year & model is your KZ750?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 22 Sep 2009 18:00 by Old Man Rock.
- Old Man Rock
Re: No Spark
22 Sep 2009 18:13
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: No Spark
22 Sep 2009 18:13
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: No Spark
22 Sep 2009 18:14
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: No Spark
22 Sep 2009 18:14
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- rayellis
Re: No Spark
22 Sep 2009 18:15
1980 KZ750E. I think I have it working and will test Wednesday. I appreciate your help.
Thank You
Ray
Thank You
Ray
