Rubber stator \"grommet\" sealer
- BARNEYHYPHEN
18 Mar 2006 12:36
What is the BEST sealant to use for sealing the large rubber grommet through which the stator wires pass, at the bottom of the stator cover?
Thought I saw WG suggesting Liquid electrical tape?
Any other suggestions? Thanks.
- The Milkman
Re: Rubber stator \"grommet\" sealer
18 Mar 2006 14:25
You can always use just good old black silicone sealer, it's cheap and easy to find. It does dissolve with gas and oil though.
Les
Les
- rtg
18 Mar 2006 14:26
Barney...I've had very good luck
1. clean the whole thing of any grease, leftover gasket sealant etc.
2. use 'HYLOMAR" to fillin crevases ,cracks and spaces (Hylomar shoud be available at any auto parts store in the gasket sealant section)
3. then use an rtv sealant on top of the hylomar.
Did mine 3 years ago just like this...no leaks yet!!
- 77KZ650
18 Mar 2006 14:46
Maybe try some "seal all" I think its oil proof, and I know its gas proof, I "patched" the bottom of an old dirt bike tank with the stuff yrs ago, there were several rust holes in it 1/4 inch in diameter:laugh: , just make sure to clean up everything first, but you know that.
Scott
Scott
07 MDP Rookie of the Year
- BARNEYHYPHEN
18 Mar 2006 15:47
Thanks for all the ideas and advice guys. I'll let you know what I do and how it turns out.
