dyna s with what coils?
  • 77KZ650
  • 77KZ650's Avatar Topic Author
18 Mar 2006 11:15
#32222
Will the dyna s ignition work as well with lower resistance coils than the green 3 ohm ones? I have read mixed opinions on here. how much of a range is there for ohms that can be used? any thoughts? thanks
Scott
Post edited by: 77KZ650, at: 2006/03/18 14:49
07 MDP Rookie of the Year
  • Mark Wing
  • Mark Wing's Avatar
Re: dyna s with what coils?
18 Mar 2006 12:05
#32227
I've used all kinds of coils , stock, hot aftermarket and dyna green coils. Thay all worked pretty much the same with the Dyna's the best but they all worked.
Mark
Yorba Linda Cal.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
18 Mar 2006 15:25
#32272
You really want to try and keep coils to 3.0 ohm minimum with the Dyna-S ignitions or the coils will run hot.
  • loudhvx
  • loudhvx's Avatar
18 Mar 2006 22:44
#32423
Dyna puts a limit of 3 ohms on the S. Most likely the output section can't handle the current demanded by lower resistance coils over time.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
19 Mar 2006 15:08
#32582
and if 2.6 was used is this out of the question ? or just close enogh to get away with it ?? :ohmy:
  • loudhvx
  • loudhvx's Avatar
19 Mar 2006 18:35
#32651
It's a question of safety margin. When manufacturers design a transistor, they publish the limitations of the parts. They usually allow for a safety margin.
Lets say you have a rope rated at 460 pounds. Sure it will probably hold more, but if you weigh 540 pounds, are you going to use that rope to climb a mountain? (No fat jokes, I chose those numbers for a reason :) )
The Dyna is rated to handle 4.6 amps. You are asking it to handle 5.4 amps. It'll probably work for a while.
Post edited by: loudhvx, at: 2006/03/19 21:36
  • Shoe48
  • Shoe48's Avatar
19 Mar 2006 20:47
#32699
Thanks for a very good answer .. I wouldnt think less than 1 amp would make much difference any idea what stock coils are ? I need to get out the meter tomorrow
  • OnkelB
  • OnkelB's Avatar
20 Mar 2006 07:19
#32774
I´ve been running electronic ignition coils (2.4 - 2.6 ohms) and a DynaS on my 650 for two years now without problems - that being said, I may just have been lucky, new 3.0 ohm Dyna coils are in the mail as we speak.
77 KZ 650 B1, 82 GPz 1100 B2.
  • 77KZ650
21 Mar 2006 22:30
#33284
Stock is around 2.2 right?
  • loudhvx
  • loudhvx's Avatar
21 Mar 2006 22:36
#33285
Stock for electronic ignition is around 2.4-ish. Stock for points is around 4-ish.
  • 77KZ650
22 Mar 2006 18:33
#33518
Ok, so my stock coils (points) will work fine, and not hurt the dyna s until I get the "green" coils... Right?
Scott
  • loudhvx
  • loudhvx's Avatar
22 Mar 2006 19:45
#33567
Scott
Yes. Nice dog you got there, by the way.
