dyna s with what coils?
- 77KZ650
18 Mar 2006 11:15
Will the dyna s ignition work as well with lower resistance coils than the green 3 ohm ones? I have read mixed opinions on here. how much of a range is there for ohms that can be used? any thoughts? thanks
Scott
Post edited by: 77KZ650, at: 2006/03/18 14:49
Scott
07 MDP Rookie of the Year
- Mark Wing
Re: dyna s with what coils?
18 Mar 2006 12:05
I've used all kinds of coils , stock, hot aftermarket and dyna green coils. Thay all worked pretty much the same with the Dyna's the best but they all worked.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Jeff.Saunders
18 Mar 2006 15:25
You really want to try and keep coils to 3.0 ohm minimum with the Dyna-S ignitions or the coils will run hot.
- loudhvx
18 Mar 2006 22:44
Dyna puts a limit of 3 ohms on the S. Most likely the output section can't handle the current demanded by lower resistance coils over time.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Shoe48
- Live each day as it is your last
19 Mar 2006 15:08
and if 2.6 was used is this out of the question ? or just close enogh to get away with it ?? :ohmy:
- loudhvx
19 Mar 2006 18:35
It's a question of safety margin. When manufacturers design a transistor, they publish the limitations of the parts. They usually allow for a safety margin.
Lets say you have a rope rated at 460 pounds. Sure it will probably hold more, but if you weigh 540 pounds, are you going to use that rope to climb a mountain? (No fat jokes, I chose those numbers for a reason
The Dyna is rated to handle 4.6 amps. You are asking it to handle 5.4 amps. It'll probably work for a while.
Post edited by: loudhvx, at: 2006/03/19 21:36
1981 KZ550 D1 gpz.
Other links.
Other links.
- Shoe48
19 Mar 2006 20:47
Thanks for a very good answer .. I wouldnt think less than 1 amp would make much difference any idea what stock coils are ? I need to get out the meter tomorrow
- OnkelB
20 Mar 2006 07:19
I´ve been running electronic ignition coils (2.4 - 2.6 ohms) and a DynaS on my 650 for two years now without problems - that being said, I may just have been lucky, new 3.0 ohm Dyna coils are in the mail as we speak.
77 KZ 650 B1, 82 GPz 1100 B2.
- 77KZ650
21 Mar 2006 22:30
Stock is around 2.2 right?
- loudhvx
21 Mar 2006 22:36
77KZ650 wrote:
Stock for electronic ignition is around 2.4-ish. Stock for points is around 4-ish.
1981 KZ550 D1 gpz.
Other links.
Other links.
- 77KZ650
22 Mar 2006 18:33
Ok, so my stock coils (points) will work fine, and not hurt the dyna s until I get the "green" coils... Right?
Scott
Scott
- loudhvx
22 Mar 2006 19:45
77KZ650 wrote:
Yes. Nice dog you got there, by the way.Ok, so my stock coils (points) will work fine, and not hurt the dyna s until I get the "green" coils... Right?
Scott
1981 KZ550 D1 gpz.
Other links.
Other links.
