Ignition switch relocation
  • sbulla
  • sbulla's Avatar Topic Author
  • 1980 KZ1000 LTD
16 Sep 2009 14:21
#322029
Any of you who have performed this, chime in, send pics, descriptions, etc.
I just installed an Acewell 2803 in place of the stock gauges and am mulling over what to do with the ignition switch. Guess I could just fab a tab and mount it off one of the handlebar bolts but, if possible, I would like to move it away from the tree and, maybe, mount it somewhere else.
Any ideas?
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
  • MFolks
  • MFolks's Avatar
Re: Ignition switch relocation
16 Sep 2009 15:19
#322036
Anywhere you relocate it to, consider making it difficult for the would be thief to break/smash to be able to drive off with your bike. Maybe use non standard hardware to mount the ignition switch like Torx or socket head cap screws(Allen Screws).
Most people don't carry around Allen wrenches or Torx tools, usually a phillips #2 or a straight slot screwdriver.
You might have to do some electrical splicing of the wires for the relocation of the switch. If you don't feel confident, get someone who can as a faulty splice(s) can strand you on the road in the future.
I like using the crimpable heat shrink splice,thats first swaged/crimped on the wire and then sealed from moisture when the outer covering is shrunk down using a special heat gun.
  • keith1
  • keith1's Avatar
16 Sep 2009 15:59
#322042
on my gs1150e, p/o had installed a small doorbell on the
on the side of where the guages mount....had to turn the key on and hit the doorbell....might not be much help to you, but the guys i rode with at the time sure got a kick out of it....:laugh:
  • mzandmz
  • mzandmz's Avatar
16 Sep 2009 16:08
#322045
I like the idea of an AUTO CAR after market ignition switch mounted down by the left side near the fuel petcock. TURN/ON/ACC/START type then your wiring can be tied into near your starter sil-o-noid. No more push button start. Keeps it somewhat invisable and your keys won't be in the way bouncing around your handle bars. But thats my way of thinking.....to each his own...:dry:
New to Family, 1979 KZ440 LTD
  • sbulla
  • 1980 KZ1000 LTD
16 Sep 2009 16:49
#322054
I was thinking about that location also. But, more underneath where it wouldn't be visible. Maybe on the other side so I could reach it without too many acrobatics.
Heck, I even thought of just using a toggle switch hidden somewhere if I knew the internal connections the switch made and how many poles the switch needed.
My brain is wore out from the gauge mounting and hook up. I'll study the schematic later...
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
  • sbulla
  • 1980 KZ1000 LTD
17 Sep 2009 05:16
#322140
Anyone know why they have two power feeds to the switch coming from the same source?
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
