Fuse types
- aforsythe
Fuse types
14 Sep 2009 07:19
Hi, I'm looking for information on which fuses to use on my 76 kz900.
I know there are 3; a 20A SFE, and 2 1OA ASB. i'm having trouble finding the 10A ASB fuses, is there an equivalent fuse i should use? and what should the voltage be on the 10's? thanks!
-Adam
-Adam
Adam Forsythe
76 KZ900
76 KZ900
- Old Man Rock
Re: Fuse types
14 Sep 2009 08:03
The OEM fuse holders... naw crapola...
Switch over to automotive blade type inline fuse holders.
These will be rated at the +12Vdc @ 20 & 10 amp ratings...
Plus any automotive parts store carries them...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- aforsythe
Re: Fuse types
14 Sep 2009 08:36
Thanks for the advice! I'll give this a try, anything i should watch out for or is there not much to it?
Adam Forsythe
76 KZ900
76 KZ900
- JMKZHI
Re: Fuse types
14 Sep 2009 09:52 - 14 Sep 2009 10:00
My 81 650-CSR still has the original fuse holders - I always have spares on hand. Never needed them, though.
Here's a reply from a recent topic: mystery problem
I'd pull the fuses one at a time and clean the clips with some Brasso and a cotton swab.Corrosion can cause overheating and melted insulation.
These older glass tubed fuses are the 1" long AGX type available at some auto parts stores and motorcycle shops.
The more common AGC type is 1 1/4" long and may not fit the fuse clips.
Last edit: 14 Sep 2009 10:00 by JMKZHI.
- Old Man Rock
Re: Fuse types
14 Sep 2009 10:10 - 14 Sep 2009 10:11
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 14 Sep 2009 10:11 by Old Man Rock.
- aforsythe
Re: Fuse types
18 Sep 2009 04:56
Thanks again! just changed the glass ones out - seems to have more juice and the dash, headlight, tail, etc lights are brighter.
-Adam
-Adam
Adam Forsythe
76 KZ900
76 KZ900
- JMKZHI
Re: Fuse types
18 Sep 2009 06:37
Did you use the individual fuse holders such as in the pic posted by OMR? Any details? Just kinda curious if you used a fuse box of any kind or are they just stuffed in behind the electro cover. Thanks.
- aforsythe
Re: Fuse types
18 Sep 2009 08:18
I used the individual ones i bought from adv auto, couldn't find a box for the inlines - would've went that route. Just black taped for now for organizing until/unless i find a better way- so essentially stuffed for now in the same area where the old box was located.
i think definitely worth the upgrade.
Just some background; my old fuse box was not holding my 20a correctly because one of the plastic holders broke off at some time and i had of headlight fuse blow and couldn't find the correct 10a replacement.
-Adam
-Adam
Adam Forsythe
76 KZ900
76 KZ900
- MFolks
Re: Fuse types
18 Sep 2009 09:46
A list of where to purchase "Blade" style fuses and holders:
www.waytekwire.com
www.rallylights.com
www.delcity.net
www.waytekwire.com
www.rallylights.com
www.delcity.net
- beazzzz
Re: Fuse types
18 Sep 2009 10:00
I just did the same thing with my 76 900. I replaced the little fuse box with the type OMR suggested, although I went with the glass type. They work great, and I just stuffed them in behind the original fuse box. I put that back in there as well just for looks. And have had no problems, so far, with about 300 miles on it since I did it.
Then:
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1980 Suzuki GS 1100 ES
1984 Suzuki PE 175
Now:
1976 Kawasaki KZ900 (2nd owner)
1977 Honda 750 K Original Owner
1978 Honda 813 K (bored out)
2004 Triumph 900 Thruxton
1966 Honda CB 160
1967 Honda CL 305
1970 Ossa 250
1971 Honda CL 450
1984 Suzuki PE 175
Now:
