Oil pressure sensor location
  • Nats82
  • Nats82's Avatar Topic Author
12 Sep 2009 20:09
#321215
Could someone tell me where the oil pressure sensor is located on a 82 550 ltd? Thanks Forum!
  • MFolks
  • MFolks's Avatar
Re: Oil pressure sensor location
12 Sep 2009 20:58
#321222
Probably the same location as on the 650's, behind the mechanical ignition advancer/pick up coil area.
  • Nats82
12 Sep 2009 21:09
#321225
Thanks MFolks I'll look in that area. Just recently, the oil light is staying on, Thought I'd check the wireing and sensor before anything eles. Thanks again!
  • Nats82
13 Sep 2009 05:58
#321263
I must be having a senoir moment, well' I'm not quite that,
I'm not blonde, so it can't be that kind of a moment, I can not for the life of me find that %#*#$ oil sensor, can some one take my hand, and point me in the right direction? again! any help or sarcastic comments are welcome, Thanks Forum.
  • chance
  • chance's Avatar
  • Life long biker/
13 Sep 2009 06:28
#321269
  • Old Man Rock
  • Old Man Rock's Avatar
13 Sep 2009 06:37
#321273
I don;t know jack about the 550 series but out of a crappy Kz550 pdf copy I have... Sensor in oil pan! ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Nats82
13 Sep 2009 07:13
#321286
Thank you OMR, you made my day
Thank you OMR, Up until now, this site has been my Manual, that I don't have, I do have one coming, Thanks again for the pics!
  • chance
  • chance's Avatar
  • Life long biker/
13 Sep 2009 07:27
#321287
Your welcome
  • Nats82
13 Sep 2009 18:32
#321418
Thank you Chance and OMR, found the sensor, wire, cleaned the connector on the wire,bolt,light went out, go figure, everything seems to be fine, for now!
  • Old Man Rock
14 Sep 2009 04:12
#321501
Excellent, now didn't that feel good fixing your own ride! :woohoo:
Now go and get yourself a OEM Kawi Shop manual and you'll be really surprised on how much you can learn about the old girl...;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
