removing rear turn signals
- 1982kz440ltd
12 Sep 2009 14:11 #321095
by 1982kz440ltd
1982 KZ440 LTD D4
removing rear turn signals was created by 1982kz440ltd
I am wondering how you remove the rear turn signals (stock) from an '82 KZ440 ltd. It appears as if the light housing is clamped onto the stem with a bolt. I removed the bolt and tried to pull the light off but it didn't budge.
I don't really care if I have to cut the wire because I'm moving the TS to another location. I just don't want to break anything.
1982 KZ440 LTD D4
- Locozuna
12 Sep 2009 14:20 #321096
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic removing rear turn signals
Sometimes ya gotta spread the light mount apart. Wedge a small flat blade screwdriver between the light mount ears just enough to get it to give up the hold. GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- 1982kz440ltd
12 Sep 2009 14:26 #321097
by 1982kz440ltd
1982 KZ440 LTD D4
Replied by 1982kz440ltd on topic removing rear turn signals
I tried that but I was being cautious. Maybe I'll be a little more aggressive with it:woohoo:
1982 KZ440 LTD D4
- Locozuna
12 Sep 2009 14:43 #321099
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Yeah they can be onery!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- 1982kz440ltd
12 Sep 2009 16:42 #321135
by 1982kz440ltd
1982 KZ440 LTD D4
I got it off.....and realized I didn't have to remove it. I thought there would be a connector by the bulb but I saw it under the seat after I had removed the housing! Oh well.
1982 KZ440 LTD D4
- MFolks
- Thank you received: 540
12 Sep 2009 18:13 #321160
by MFolks
Replied by MFolks on topic removing rear turn signals
With the rear turn signals out of the circuit, the front ones(if you have them) may not flash unless you replace the one in the siver can with a newer electronic one(usually found at auto parts stores).
