Coils- where or how 2 find out what ohm they are
- paradon
09 Sep 2009 18:20 #320273
by paradon
Coils- where or how 2 find out what ohm they are was created by paradon
83 kz550m1, thought I could look on them n find out what ohm they were. I was wrong, only thing I could find was -ZC006-TR12v- any help would be great.
- MFolks
- Thank you received: 540
09 Sep 2009 18:55 #320283
by MFolks
Replied by MFolks on topic Coils- where or how 2 find out what ohm they are
Most bike coils are rated between 2.2 and 3.0 OHMS. Anything less may have the coils overheating. Bikes have used 4 ohm coils, but the spark energy is reduced.
Kinda like a tightrope to walk between endurance for the long haul or really short lived performance.
- Thank you received: 2098
09 Sep 2009 19:19 #320296
by Patton
Replied by Patton on topic Coils- where or how 2 find out what ohm they are
paradon wrote:
Is it the stock ignition with igniter, and perhaps the stock ignition coils, or possibly replaced with a different ignition such as Dyna-S which doesn't use the igniter?
Many conversions to Dyna-S also use the 3 ohm Dyna green coils (the majority I believe ), but some may prefer the Dyna 4 ohm coils.
May use ohmmeter to measure resistence of a coil, by reading across the coil's primary winding terminals.
Good Luck!
Good Luck!
- paradon
09 Sep 2009 20:24 #320313
by paradon
Replied by paradon on topic Coils- where or how 2 find out what ohm they ar
Everythings stock on the motor, for now. Figured just up grade now n then when I do get the dyna ingition I will b ready. $ workn on that short budget. Sounds like 3 would b ok 2 go with?
09 Sep 2009 20:39 #320319
by Patton
Here's a link to a lower priced 4 ohm coil from Z1E.
Haven't tried them, but see favorable reports, and thinking some very knowledgeable folks prefer 4 ohm over 3 ohm ignition coils with Dyna-S ignition.
Click here >> Lower priced 4 ohm coil
Am well-satisfied with the green Dyna 3 ohm coils and Dyna-S ignitions. Could be wrong, but thinking Dyna recommends the green 3 ohm coils with the Dyna-S ignition, as opposed to the Dyna 4 ohm coil. Other members will likely have better information about this.
Good Luck!
Good Luck!
- bountyhunter
- Thank you received: 337
09 Sep 2009 22:36 #320348
by bountyhunter
Replied by bountyhunter on topic Coils- where or how 2 find out what ohm they are
On a points ignition with no external ballast resitor, I would not go lower than four Ohm coil. With the kawi electronic igniter type ignition, they run lower resistance coils like about three ohms. With aftermarket like Dyna, I think they also wun lower resistance coils.
You can measure the coil resistance if you have a GOOD ohm meter with a low range like 200 Ohms or less, and you "zero out" the lead resistance to get an accurate reading.
- paradon
10 Sep 2009 07:50 #320394
by paradon
How will I know if I hav the electronic type? I m assumen I have the points. So I could go with the ones pasted up n another post? Lots cheaper, witch is good till I can up grade everything at once
- loudhvx
- Thank you received: 1616
10 Sep 2009 08:11 #320396
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Coils- where or how 2 find out what ohm they ar
If you will someday use a Dyna S, you should get 3 ohm coils. They should still work with your stock ignition (which used coils in the 2.4 to 2.6 ohm range).
1981 KZ550 D1 gpz.
Other links.
