melted solenoid
- clutch85
04 Sep 2009 18:13 #319133
by clutch85
melted solenoid was created by clutch85
hello i am trying to rewire a 1980 kz440 and i am probably the dumbest person when it comes to this stuff but there is only one way to learn, any way like an idiot i didnt use any fuses and i had an issue when i tried to start the motor and the wire from the positive side of battery got really hot and melted a hole thru the top of the solenoid where the corresponding terminal is. I found some bare spots on the wire and the wire that goes to the rectifier and think they may have touched and caused it My question is did i possibly ruin any other components and where can i find the cheapest replacement for the solenoid
thank you !!!!!!
thank you !!!!!!
- MFolks
- Thank you received: 540
04 Sep 2009 18:31 #319139
by MFolks
Replied by MFolks on topic melted solenoid
Take your solenoid to the nearest riding lawnmower shop. They have solenoids tha should fit after a little work.
The dealer probably wants $$ but for less than $15 you'll get a solenoid to get back on the road.
I'd suggest getting some new battery cables made up.Most welding supply stores sell 6 gauge welding cable by the foot and the battery stores can probably crimp/swage on new terminal ends for the new cables.
- clutch85
05 Sep 2009 11:40 - 05 Sep 2009 11:46 #319284
by clutch85
Replied by clutch85 on topic melted solenoid
Last edit: 05 Sep 2009 11:46 by clutch85.
- clutch85
05 Sep 2009 11:53 #319285
by clutch85
Replied by clutch85 on topic is this what it should look like?
the one i bought has two big terminals and a space connector it is a 12volt lawn mower solwnoid will it work? tried to upload pic but dont know how
thank you!!!!!!!!!!
thank you!!!!!!!!!!
