KZ1000 right hand control
  • markdavjones
  • markdavjones's Avatar Topic Author
04 Sep 2009 16:02
#319113
Having been unable to locate a decent right hand control for my 1978 KZ1000 A2, I purchased a reproduction control right-hand switch for the Z1 models from 1974 and 1975
Code: RSP745 from american classics,
www.americanclassix.com/kawaElectrical.html
Though slightly different, it works perfectly. The picture shows how I wired it. Just an FYI in case anyone else is having this problem.
The following user(s) said Thank You: kaw788182
  • chance
  • chance's Avatar
  • Life long biker/
Re: KZ1000 right hand control
04 Sep 2009 16:30
#319116
On my 78 the wires go internaly in the bars and has no slot for the wires to come through .Is it metal ? will they reach through the bars? Good Info to know. Thanks
  • markdavjones
08 Sep 2009 12:11
#319884
I've been running aftermarket superbike bars for last 27 years, so my wiring is external to the bars. I don't remember if the wiring was internal originally or not but the wires should be plenty long enough either way.
08 Sep 2009 14:18 - 08 Sep 2009 14:18
#319932
Z1E also carries similar switches.
Right side
Left side
Good Luck! :)
Last edit: 08 Sep 2009 14:18 by Patton.
  • markdavjones
08 Sep 2009 16:47
#319976
Yes, the ones from Z1E are the same reproduction units I used. They seem to very good quality.
  • timebomb33
  • timebomb33's Avatar
08 Sep 2009 16:51 - 08 Sep 2009 16:52
#319978
stock bars were internally wired but who kept the stock bars and the wiring is more than long enough unless your switching to ape hangers
I THINK MY POWERBAND BROKE
Last edit: 08 Sep 2009 16:52 by timebomb33.
  • treyzx7r
  • treyzx7r's Avatar
13 Mar 2011 07:00
#437616
thanks for the advice i have been looking for month to find a replacement. called all the usual suspects.
  • stonemaster
  • stonemaster's Avatar
13 Mar 2011 08:35
#437635
+1
  • mvent
  • mvent's Avatar
27 Jul 2011 16:34
#465345
This photo is very helpful to me, but does anyone know where the black wire is coming from on original harness that the black wire from new switch housing plugs into?
Thanks
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
27 Jul 2011 18:27 - 27 Jul 2011 18:27
#465362
mvent wrote: This photo is very helpful to me, but does anyone know where the black wire is coming from on original harness that the black wire from new switch housing plugs into?
Thanks
If not already done, would take a look at wiring diagram under FILEBASE.
Good Fortune! :)
Attachment filebasekzr.jpg not found
Last edit: 27 Jul 2011 18:27 by Patton.
