signals, left and right
- Iron Duke
- what are you rebelling against?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- MFolks
- Thank you received: 540
- RetroRiceRocketRider
- Thank you received: 29
If it doesnt auto-cancel after say, 200 feet, then it's likely unplugged, has a dirty connection or has simply gone bad.
- Phildo
- Thank you received: 2829
- Thank you received: 2098
how can we tell if we should have this feature or not?
Thinking it should be referenced in manual and/or wiring diagram.
Good Luck!
- bountyhunter
- Thank you received: 337
My '79 sure doesn't have self cancelling turn signals. You can easily make an add on by building a solid state flasher to blink the turn signals using a 555 timer and power it from another 555 wired up as a one-shot which turns on for maybe 15 seconds and then times out. The blinking stops even if the TS signal switch is still in the ON position. I was lazy and just added a loud beeper that barks when the TS blinks because that was easier.I don't know when Kaw started putting those new-fangled modern space-age gadgets on motorcycles, but they weren't there in 1977. Anyone know what year was first to have them? Ed
- grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- JakeB
1978 Z1-R
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
