'78 Kz1000a motor in '79 Kz1000ltd wiring?
- Zoo Mob
02 Sep 2009 13:11 #318612
by Zoo Mob
'78 Kz1000a motor in '79 Kz1000ltd wiring? was created by Zoo Mob
Just bought a '79 KZ1000 LTD w/a '78 Kz1000A motor in it, there are some things left disconnected, starter doesn't spin, no neutral light etc. What will need to happen here? Is everything the same between the two motors? Here's some pics below.
s42.photobucket.com/albums/e337/zoomob/?...current=IMG_1405.jpg
- chance
- Life long biker/
02 Sep 2009 15:19 - 03 Sep 2009 07:14 #318642
by chance
Replied by chance on topic '78 Kz1000a motor in '79 Kz1000ltd wiring?
The wire on the ground is youe alt. wire and the round rubber plug is for your oil press. light that goes under the carbs the plug should plug up around the fuse box area the white wire goes to the power white wire in the fuse box area.The wires in your hand seem to be rear lighting wires. The bottom pic shows a breather hose that goes to the air box and 2 carb vent lines
Last edit: 03 Sep 2009 07:14 by chance. Reason: misspelling
- chance
- Life long biker/
02 Sep 2009 16:55 #318666
by chance
Those carbs look like 29mms
