KZ 650D won't start, help!!! Fixed!!
- 2006hhr
01 Sep 2009 20:09 - 02 Sep 2009 17:52 #318428
by 2006hhr
KZ 650D won't start, help!!! Fixed!! was created by 2006hhr
Went to move my 650 around front in anticipation of a morning ride, didn't notice that i had the red wore off the Dyna S ignition across the frame rail and when i plunked my rotund butt on the bike, the red wire got pinched, fried the main fuse and now the bike refuses to spark. I don't know if it is a case of the ignition being fragged or a different problem as i can't get the starter motor to turn with the clutch disengaged and kicking does nothing. I can get the motor to turn over via crossing the starter solenoid, so which way to go, new ignitor or am i going to be tracing electrical gremlins all weekend. I am going to send the ignition off to Dyna to inspect and see if it is the problem. Other than spark, i have good power to the headlight, taillight and main power.
Last edit: 02 Sep 2009 17:52 by 2006hhr.
- 2006hhr
01 Sep 2009 20:40 #318449
by 2006hhr
Replied by 2006hhr on topic KZ 650D won't start, help!!!!!!!
K talking to myself, here goes. if the handlebar switch on the right pod is fragged, would it be doing the same thing, no electric boot from the button, no sprk, etc. There is literally no spark getting to the coils right now, just a thought
- 2006hhr
02 Sep 2009 17:51 #318677
by 2006hhr
Fixed, kill switch was dead. Wired a 2 pole switch into the harness and bike runs fine, just a case of jumping the gun.
