DYNA 2000 wiring the tach.
- kano
- Not Another Bloody Limey!
30 Aug 2009 14:37 - 30 Aug 2009 14:42
it says in the manual for the installation of the dyna 2000 connect the green wire (for me) to the input wire for the tach!
so which one is it :woohoo:
i didn't want to risk my normal trial and error method :blush:
anyone know the colour of the input wire for a kz1000 J motor.
Last edit: 30 Aug 2009 14:42 by kano.
- timebomb33
Re: DYNA 2000 wiring the tach.
30 Aug 2009 16:56
they want you to use one of the main trigger wires from your ignition plate. it wont matter which one.
I THINK MY POWERBAND BROKE
- chance
- Life long biker/
30 Aug 2009 16:57
It's the Kawasaki green one. You know what wire it is you just want to see if we know. I'd walk outside and check but my feet hurt...lol
- kano
30 Aug 2009 17:00
timebomb33 wrote:
main trigger wire? dude im a carpenter not a electrician :woohoo:
can you give me a colour? of this wire plz? :S
- OnkelB
31 Aug 2009 05:54
On each ignition coil you have a 12V supply wire (red or red/yellow) and a trigger wire - the trigger wire on one coil is black, on the other it's green. You can use any of the trigger wires (black or green) to feed the tach.
77 KZ 650 B1, 82 GPz 1100 B2.
- kano
- OnkelB
31 Aug 2009 07:02
Hey Kano, just sent you a PM, please read.
- kano
31 Aug 2009 07:14
roger that !
thanx for the heads up.
i was looking for a excuse to sit here watching the moto gp
and not go wire it up :woohoo:
- OnkelB
31 Aug 2009 07:29 - 31 Aug 2009 07:29
As I said in my PM I didn't read your original question correctly, sorry - I consulted my diagrams and the Dyna 2000 installation guide and this should be correct:
In the stock configuration the tach reds off the black trigger wire connected to one of your ignition coils - in other words the tach input wire is black. It may not connect directly to the coil terminal, but you should be able to find it at the tach plug.
Connect the black wire going to the tach to either the green or the yellow wire coming out of the Dyna 2000 - I'm not sure which one, but if your tach seems significantly off (like showing half or double what it used to) use the other one.
After connecting the Dyna 2000 to your coils you do not want to have the black tach input wire connected to the coil anymore as the tach is now triggered directly from the Dyna 2000.
Hope this helps you some.
Last edit: 31 Aug 2009 07:29 by OnkelB.
- kano
31 Aug 2009 07:36
thanks a lot it is much clearer now,
appreciate you taking the time to look
into this for me dude.
- OnkelB
31 Aug 2009 07:41
No problem, you're welcome. I'm in the middle of reworking the wiring on my 1100 so no big detour.
