kz440 project
  • clutch85
  • clutch85's Avatar Topic Author
kz440 project
29 Aug 2009 16:15
#317411
hello i just recently bought a 1980 kz440 that has been half way modified owner planned on making a bobber which is what i paln to do. Didnt feel right chopping up a good bike so i bought one that has already starting that journey. Anyways the electrical is a mess and i am trying to wire it. I have zero knowledge about anything that has to do with bikes but i wanted to learn so i thought i would do my best to figure it out. My question is how could i bypass the ignition switch. It was missing on the bike and right now i just want to hear the engine run and am wanting to do the bare minimum required to do that. Thank You!
Re: kz440 project
30 Aug 2009 08:30 - 30 Aug 2009 08:40
#317546
Here's a link to some downloadable on-site info, including wiring diagrams, tuning, etc. Click here >> On-Site Info
The ignition coil has two primary terminals, each connected to a small wire.
One such small wire supposedly feeds battery positive voltage to the coil (perhaps a red/yellow wire) when the ignition switch is ON.
A hot wire may be used as a test wire from the positive battery terminal in lieu of or in addition to the described red/yellow wire.
Okay to leave the hot wire connected while engine is running, but should be disconnected when the engine isn't running. Because could burn up the coil if left attached (same as just leaving the ignition switch in the ON position) by feeding continuous voltage into the coil while it isn't being used.
With a properly functioning ignition system, the other small wire repeatedly grounds and ungrounds the coil's primary windings. When grounded, the coil charges. When ungrounded, the coil fires through the plug wires.
Good Luck! :)
Last edit: 30 Aug 2009 08:40 by Patton.
