will this work?????
- 81ltd550
21 Aug 2009 13:48 #315548
by 81ltd550
will this work????? was created by 81ltd550
will a wire harness off a 81 kz550D work on my 81 kz550c
- loudhvx
- Thank you received: 1616
21 Aug 2009 14:31 #315552
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic will this work?????
Some parts will, some parts won't. The wire length is probably shorter in some areas. If it's not a new harness, it's probably not worth the money and effort since all old harnesses tend to have the same problems in the same areas. You may only be trading one set of problems for another.
I've taken apart probably a dozen KZ harnesses down to the last wire and they all tend to have frayed/broken wires in the same areas.
Most notably in the frame-to-headlight area, the battery/fusebox area and various pinch/rubbing areas.
If you just concentrate in those areas, replacing/splicing wires, you'll probably come out ahead.
1981 KZ550 D1 gpz.
Other links.
- 81ltd550
21 Aug 2009 15:13 #315563
by 81ltd550
Replied by 81ltd550 on topic will this work?????
there is a huge bunch of wires right behind the headlight is cut right off
cgi.ebay.com/ebaymotors/K86-1980-1981-Ka...fPartsQ5fAccessories
this is the one im gonna buy, will it work?
- Royal1MC
- Is it just me, or is it just great to be on a KZ
21 Aug 2009 16:06 #315566
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic will this work?????
I looked at the diaghrams for both, they look very different as far as the connectors.
Los Angeles, CA
- violentvintagecycles
21 Aug 2009 16:21 #315567
by violentvintagecycles
Replied by violentvintagecycles on topic will this work?????
chances are.. NO.. I have an 82 kz550a3, bought a c model harness, not even close.
