battery question?
- thompsonmx100
20 Aug 2009 21:35 - 20 Aug 2009 21:35 #315445
by thompsonmx100
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
battery question? was created by thompsonmx100
I am building a cafe racer as some of you may know. I want ot know what is the smallest battery that I can buy that will still crank a gpz 750 over. I plan on putting this battery under the seat of my cafe I don't have a ton of room.
1985 gpz750
Kz 650
Last edit: 20 Aug 2009 21:35 by thompsonmx100.
- MFolks
- Thank you received: 540
20 Aug 2009 22:35 #315451
by MFolks
Replied by MFolks on topic battery question?
I'd suggest going to the Yuasa battery website and look at what they've got to offer. You will need what is called CCA or cold cranking amperes to start the engine.
If you have a high compression or run FI then it becomes more complex to figure out.
Finding the max cca in a small package might be difficult.
- MFolks
20 Aug 2009 22:52 #315454
by MFolks
Another thought: Run the largest cable you can to where the battery will mount for maximum current flow. I'd suggest 6 or even 4 gauge welding cable because it's very flexible. It comes in two colors; RED and BLACK. I'd imagine a battery shop could swage/crimp on the correct sized terminals on the cables.
- thompsonmx100
20 Aug 2009 23:12 #315456
by thompsonmx100
1985 gpz750
Kz 650
Replied by thompsonmx100 on topic battery question?
what is the cca of a gpz 750 battery. my manual doesn't tell me and the yuasa website doesn't tell me:angry:
1985 gpz750
Kz 650
- timebomb33
- Thank you received: 10
20 Aug 2009 23:14 #315457
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic battery question?
a freind of mine is using a ytz 9 yuasa battery in his 1166 gs1100 street bike and he has had good luck with it. and it is a quite small battery. compared to the stock battery.
- thompsonmx100
21 Aug 2009 00:09 #315471
by thompsonmx100
1985 gpz750
Kz 650
yeah that was what i was thinking the ytz is a small sized battery might be a tight fit. I have some 4 gauge wire that I'm gonna use I should be able to put ends on it myself. the ytz is rated at like 190 cca what is the zx750 battery supposed to be rated at 12 cca?
1985 gpz750
Kz 650
