coil wires
- krazinite2003
coil wires
19 Aug 2009 18:49
ok new guy question
i have an 83 KZ750 L3 my question is on the coils there is two wires to each "cant remember the colores " does it matter which color goes where if it does can some one tell me where they go
please
oh and FYI i have found the owners manule for this bike with all the specs for it
please
i have two 1983 kz750 L3
Re: coil wires
19 Aug 2009 19:09 - 19 Aug 2009 19:11
krazinite2003 wrote:
There are two ignition coils.
One coil fires the two outside sparkplugs.
Other coil fires the two inside sparkplugs.
Each coil receives battery+ voltage to one of its primary terminals through a wire coming from the igniter. Perhaps a red wire.
The coil firing the two outside sparkplugs receives signals at its other primary terminal through a wire from the igniter. Perhaps a black wire.
The coil firing the two inside sparkplugs receives signals at its other primary terminal through a wire from the igniter. Perhaps a green wire.
The manual should include a wiring diagram.
Or may click here > '83KZ750 Information
and then download the wiring diagram.
Good Luck!
ok new guy question
please
Good Luck!
Last edit: 19 Aug 2009 19:11 by Patton.
- MFolks
Re: coil wires
19 Aug 2009 19:18
I have an 82 GPZ1100 B2, and looking at my shop manual wiring diagram, the left ignition coil has two wires, a RED wire and a Black wire going to the coil. The right coil has two wires,a RED wire and a GREEN wire.
Now 650'and 750's may have the wiring switched from what Kawasaki did on the 900's,1000's and 1100's, if that's the case reverse the wiring from what I told you.
See if the wires will reach the coil connections without pulling or stretching.
- krazinite2003
Re: coil wires
20 Aug 2009 04:57
maybe i was unclear left side coil has a red wire and a black wire i think i have the red on the bottom and black on the top conection is this right
- Motor Head
Re: coil wires
20 Aug 2009 05:18
The red are the positive wires from your ignition switch, the other are your trigger wires from the pick-up coils. Look at the ignition coils, near the terminal where the wire goes on you will see a + and a -. Red to + for sure.
Then at worse you may have the wires for the plugs off, as 1 coil fires 2 plugs. 1 does 1&2, the other 3&4.
Hope this helps.
Hope this helps.
- krazinite2003
- JR
Re: coil wires
20 Aug 2009 06:06
Does not matter which is top and which is bottom
- Motor Head
Re: coil wires
26 Aug 2009 18:53
YES IT DOES!
There is a Positive and a Negitive for all Ignition coils!
Just check the coil near where the wire hooks up, it has the + & - symbols. Red Positive.
- timebomb33
Re: coil wires
26 Aug 2009 19:26
most of the aftermarket coils don't have any polarity differences stock ones do though.
I THINK MY POWERBAND BROKE
