- Thank you received: 3
hotter plugs?
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Old Man Rock
- Thank you received: 225
One, do you have +12Vdc at the coils, then the wiring mod will do nothing for you...
Maybe this will help.... See attached...
Or download.... kzrider.com/index.php?option=com_docman&...d&gid=448&Itemid=108
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 9am53
My bike has 2 different coils, and both are old ass so when I replace the ignition system I will swap them out too.
'84 GPz900r
'71 CB350
- 9am53
'84 GPz900r
'71 CB350
- mzandmz
New to Family, 1979 KZ440 LTD
- 9am53
'84 GPz900r
'71 CB350
- KOOL RYDER
- KZ 650B2 / KZ 1000E
(I just did it, I was at 10.42 volts at the coils and it helped a lot.)
I now run B7ES plugs. Before the mod I ran the B7ES plugs and they did last a lot longer than the B8ES.
So, if you do nothing with your bike and all you do is swap out plugs, they will help a bit and last longer, but they will still eventually foul if you do not address the other issues with your bike.
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- mzandmz
- 9am53
To answer your question about plugs, do as stated above and check the voltage to the coils. Get a multimeter and check the voltage at the battery and then check the voltage at the coil by grounding the (-) and placing the positive terminal in the single hot wire that splits into 2. That will indicate wheter you need to do the WGCM.
KR
THanks...the only issue is that someone messed around with my wiring, so there is no wire that splits to the 2 coils. I wanted to do the mod a while ago but the wires had me all confused. I will check out my voltages and then figure out if I need the mod (and likely return with more questions about the mod!) if the fouling problem persists then I will swap plugs.
Thanks for explaining
'84 GPz900r
'71 CB350
- bountyhunter
- Thank you received: 337
Not really, there is a lot of wind drag on a bike and it's engine has to make a fair amount of power to cruise at that speed. You do have good airflow, but the cylinders are making a ton of heat that flows outward.Hi, if I spend most (about 85%) of my time on backroads doing 60 mph cruising, my engine is running relatively cool right?
9am53 wrote:
All of them look the same, or just a couple?I am regularly carbon fouling my plugs.
9am53 wrote:
I don't think that's the real fix. I know on the twins where the standard plug is the hottest B6ES, people go UP to the cooler B7ES for highway cruising where the engine makes more heat than at low speed operation. I don't think going hotter than stock for highway speed is right, I think it's backwards.could a B7ES plug set maybe help too?
Either you are running rich or maybe there is an ignition problem.
- Thank you received: 2829
- 9am53
When I get the money to have my valves done they are going to synch my carbs, would they know then if they were not set up right?
I think tomorrow I will get a sec to check my ignition voltages and I will post the results. I have read many times about people pulling plugs and checking the colour of the spark, how do you do that? Would I pull a plug out then start the bike while holding the plug wire (I have dyna wires with no caps) and hold the plug close to the engine?
'84 GPz900r
'71 CB350
