Z1 KZ timing advancer question
- tworevs
I am working on my 74 Z1-A 900/1075-29 smoothbores.
1 and 4 are not running as clean as 2 and 3. I just put in new dyna coils and added WG's relay setup to the ignition system. Carbs are in great shape and compresion is 145 all cylinders.
So I am going to replace my old dyna 3 with a dyna s. Z1 Enterprizes mentions a different rotor for the early advancer ( 5 btdc ) and the later advancer (20 btdc ).
Does anyone know which advancer would work the best in my engine. I have the early one in it now but also have the later one on a kz parts bike.
Which one to use ?
Thanks, Todd.
74 Z1 900 and 77 KZ 900
- Samwell
- Thank you received: 1
This is my first post. Love this site. You guys have been a great help.
Which one to use ?
Thanks, Todd.
First off, welcome! You'll find lots of differing opinions on what to do with your ride (which looks really sharp by the way!). The only things we do agree on are: 'Old Kawi's rock', and 'ride that bike!'
My personal opinion is to keep the one that came with the bike; not that I'm an original parts nut or anything. It may just work like it was supposed to. Just make sure its in good shape. Your Dyna S is a 'set and forget' setup, but you can use a timing light to check your advancer is working properly.
Were the 1&4 cylinders having trouble before the mods or after? Check the voltages at both coils (just to make sure you did both sides properly) and double check all of your grounds. I'm assuming that the wires, caps and plugs are new too. If all else fails, swap the coils around see if the problem moves. If it does, then it could be a coil issue, if not, there may be an issue with the Dyna S (or the wiring to/from it).
hope this helps...and I'm not a real mechanic, I just play one in my garage!
- Jeff.Saunders
www.z1enterprises.com
Z1 Ent on Facebook,
- tworevs
Thanks for your help, Todd.
- Jeff.Saunders
The higher compression coupled with the crappy fuel these days... this should also reduce/eliminate the detonation (pinging) rolling on through the mid-range.
Z1 Ent on Facebook,
