750 twin starter clutch ????
- jake100
15 Aug 2009 14:55 #314105
by jake100
750 twin starter clutch ???? was created by jake100
Just what fails on these things some times it slips (alot) I took it apart I was hopeing that a spring would be broken/missing. But all looks good no obvious sign of anything damaged.?? Would a little stronger spring be in order?? Thanks Jake
- MFolks
- Thank you received: 540
15 Aug 2009 15:21 #314107
by MFolks
Replied by MFolks on topic 750 twin starter clutch ????
What type/grade of oil are you using? Some of the auto oils contain a friction modifier that can cause slipping.
I've read/heard the Shell Rotella 15W40 and 20W50 works well in the Kawasaki air cooled engines.
- bountyhunter
- Thank you received: 337
15 Aug 2009 16:41 - 15 Aug 2009 16:42 #314116
by bountyhunter
Replied by bountyhunter on topic 750 twin starter clutch ????
jake100 wrote:
Look for wear on the hub surface the rollers engage. Also, saw wear inside where the rollers retract to. I don't think stronger springs will do a thing as they don't apply the engaging force and that would keep them from retracting as they must do.Just what fails on these things some times it slips (alot) I took it apart I was hoping that a spring would be broken/missing. But all looks good no obvious sign of anything damaged.?? Would a little stronger spring be in order?? Thanks Jake
Last edit: 15 Aug 2009 16:42 by bountyhunter.
- jake100
15 Aug 2009 22:37 #314264
by jake100
Replied by jake100 on topic 750 twin starter clutch ????
Well I'm useing Kendall motorcycle oil and like I say hub looks smooth nothing look real chewed up or worn out the only sign of possable wear is on the things (plungers) that are on the end of the springs that contact the rollers. The manual doesn't give any wear specs on these however. Jake :dry:
- bountyhunter
16 Aug 2009 16:49 #314432
by bountyhunter
Look at the areas in the housing that the rollers rub across as they go in and out. If there is any roughness, it may be keeping one of the wheels from popping back out correctly.
