lost spark
- dadoo
15 Aug 2009 13:28 #314089
by dadoo
lost spark was created by dadoo
i have a 1980 ltd 1000 with <10000 miles. bike runs great and then i lose spark to cyls. 1&4. if i pull plug wire on #4 and hook up and ground to engine another plug while bike is running #1 cyl. will pick up and i get spark to #4. when i switched coil 1&4 to 2&3 problem stayed with 1&4 cyl. coils as well as igniter check out within specs using ohmeter. i was told the p/u coils may be bad. does anyone have a set for a cheap price or i have other kz parts like handle bar light switches and parts for kz1000,gauge cluster for kz440 4ohm coils and k/n pods for kz650 to trade.
thanks,
dave
thanks,
dave
- mzandmz
17 Aug 2009 08:49 #314577
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic lost spark
Any answers yet? Did you get her fixed?
- bill_wilcox100
- Thank you received: 5
17 Aug 2009 09:07 #314579
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic lost spark
dadoo, welcome to the KZR nation. Great to have you here.
IMHO, you could use the 4 Ohm Coils you have for trade... if they fit mechanically.
Points ignition systems usually call for 5 Ohm Coil(s) and my Dyna S Electronic Ignition system calls for 3 Ohm(s)... so at 4 Ohms you are kind of in the middle.
The points should wear out just a little faster and the e-ignition should produce a little less spark but this could be a work-around solution that gets you on the road now. Then you can implement a longer term solution over the winter months.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
- bountyhunter
- Thank you received: 337
17 Aug 2009 13:44 - 17 Aug 2009 13:46 #314616
by bountyhunter
Replied by bountyhunter on topic lost spark
I believe the Kawi OEM coils for points ignition are four Ohms. That's what mine is. A four or five Ohm coil should work fine. Z1 sells the OEM replacement four Ohm coils for $36.
It probably is not the coil.when i switched coil 1&4 to 2&3 problem stayed with 1&4 cyl.
Last edit: 17 Aug 2009 13:46 by bountyhunter.
- dadoo
17 Aug 2009 20:08 #314678
by dadoo
Replied by dadoo on topic lost spark
the ignition coils check out fine. what i was told i may need are the eletronic ignition pick up coils. have'nt had time to mess with this past weekend, maybe tomorrow.
thanks for everyones input.
dave
dave
