need timing and carb help in OKC, OK area.
- ndeli55
1978 kz650B stock
1973 rd250 (in 1000 pieces)
- keith1
- Thank you received: 2
- ndeli55
1978 kz650B stock
- keith1
a lot of variables......good luck....
- ndeli55
1978 kz650B stock
- ndeli55
1978 kz650B stock
- keith1
its the same on the small fours 1/4 and 2/3 fire together. I finally got a decent tune on it, I am now worried that I have run too lean. I went from 105's to 100's on jet size. The 105s were running pretty rich, and would sometimes plume black smoke. I just happened to have 100's so I threw those in, a little air fuel screw adjustment, and now its better, not best but better. I also think I may have fouled a plug. I am going to look at repowering the coils, and I ordered a dyna s ignition.
dyna s is a good place to start...rules out the points and its set it and forget it....i would still check battery voltage after sitting overnite...anything less than 12v putting a multimeter on dc volts and putting red on pos and blk on neg is a weak battery, which will screw up the whole works.....you are cutting fuel down and are still fouling a plug....i am far from an ase tech ,but you might have an low voltage problem......good luck and let us know how ya make out......
- ndeli55
1978 kz650B stock
- ndeli55
I think its the right direction, I have 102.5s to through in there tomorrow.
1978 kz650B stock
