starting problem
- bobbie13
starting problem
08 Aug 2009 09:10
my battery is new and fully charged but when i crank it the voltage drops to 7 volts. if i jump start it, then it shows it's charing and will restart immediately. but if i let it sit for a minute i'll have to jump it again. i can't find any wires shorted out, but the wires coming out of the start are pretty warm and have lower voltage. could my starter be the problem?
- Old Man Rock
Re: starting problem
08 Aug 2009 10:46
You'll have to give us some clue as to which KZ/Kawi your speaking of... Year and Model....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bobbie13
- bountyhunter
08 Aug 2009 14:36
It could be the starter drawing too much current, but the symptoms sound more like a weak battery since the thing will restart after you run it a bit which pumps the battery up some. Not all new batteries are good. Also, jump starting would probably not work if the starter was over drawing since you would get a big voltage drop across the jumper cables.
Only way to tell is measure the starter current with a clip on Ammeter when cranking the engine.
- bountyhunter
08 Aug 2009 14:38
bobbie13 wrote:
I would check and clean all the high current connections starting at the battery terminals going to the starter and be SURE to check the ground connections to the frame.
- MFolks
08 Aug 2009 14:43
A loose ground connection,some rust or corrosion, and you've got a hard to start bike.Add to the mix a marginal battery with worn down brushes and gummed up bushings on the starter motor and it becomes almost impossible to use the electric starting system.
08 Aug 2009 16:44
bobbie13 wrote:
Would assure fluid levels in battery are correct. Helps to see levels if shine flashlight through from back of battery.
Would also perform specific gravity test (little floating balls) to help verify condition of battery. A load test is probably the best diagnostic of battery condition.
Also heed advice regarding connections, etc.
Good Luck!
Good Luck!
- bobbie13
09 Aug 2009 07:19
thanks for the help. I'll be tinkering with it some today and let you know what i find...thanks again....
