Running Brake Light ??
- oxcadillacxo
07 Aug 2009 11:32 #312235
by oxcadillacxo
78 Kz650 Sr
Running Brake Light ?? was created by oxcadillacxo
ok i have a 78 kz650 sr my brake light works but it doent stay on it only comes on when i push the brake pedal !! how do i make it come on and stay on and then get brighter when i push the pedal ??? please help i wanna go on a night ride tonight !
78 Kz650 Sr
- Johnj
07 Aug 2009 11:39 #312239
by Johnj
Veho vivo - Ago ut veho
Replied by Johnj on topic Running Brake Light ??
There are two lights in the bulb, a tail light and a stop light. You have a problem with the tail light side. Have you removed the red lens and looked at the bulb yet?
- oxcadillacxo
07 Aug 2009 11:47 #312242
by oxcadillacxo
78 Kz650 Sr
Replied by oxcadillacxo on topic Running Brake Light ??
yea i put a new bulb in i dont have the trun signals hooked up so there is a couple of wires not hooked up if my brake light works when i push the pedal should the running light still work or is there other wires that need to be hooked up
78 Kz650 Sr
- Royal1MC
- Is it just me, or is it just great to be on a KZ
07 Aug 2009 12:13 #312245
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Replied by Royal1MC on topic Running Brake Light ??
Have you seen if your headlight is working? Do you have a on/off switch that controls the headlight and taillight?
Los Angeles, CA
- donthekawguy
- Thank you received: 8
07 Aug 2009 12:22 #312248
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Running Brake Light ??
You have the running light wire unhooked. Get a tester, turn on the key, test all the wires until you find the one that is hot, plug it in.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- bill_wilcox100
- Thank you received: 5
07 Aug 2009 12:52 #312256
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Running Brake Light ??
Your Tail Light is the Red wire.
Your Stop Light is the Blue wire.
Your Ground Return or (-) Battery is the Black/Yellow wire.
Sounds as if your Red wire is not connected or open circuit. Be prepared to test your Red wire for (+) Battery Vdc, to clean all connector contacts and or to repair or replace the Tail Light socket.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
