Good Spark Plugs to Buy?
  • mzandmz
  • mzandmz's Avatar Topic Author
05 Aug 2009 16:14 - 05 Aug 2009 16:15
#311828
Hello, What plugs are the best to use in 77 KZ650? Are Hotter plugs good to use?I live on the Oregon coast avg. temp summer is 65deg. Winter is 38deg. Always seems have moisture in the air and lots of wind
New to Family, 1979 KZ440 LTD
Last edit: 05 Aug 2009 16:15 by mzandmz.
  • TexasKZ
  • TexasKZ's Avatar
Re: Good Spark Plugs to Buy?
05 Aug 2009 16:25
#311831
Unless you are experiencing a problem, it's generally best to stick with the factory recommended heat range. Regular NGK plugs are high quality and reasonably priced. Again, unless you have a special need, esoteric plugs (platinum, iridum, silver, et cetera) are mostly a waste of $$$$$.
A better question might be, what is the best oil and chain lube?;) :lol: :P :silly:
  • MFolks
  • MFolks's Avatar
05 Aug 2009 16:36
#311834
Stock sparkplugs in the bigger older 4's is NGK B8ES or Denso W24-ESU's gapped 0.028 to 0.032 diameter.
Other brands like Accell,Bosch and maybe Autolite can be used. I'd stay away from Champion sparkplugs(bad personal experiance).
Put a dab of the silver anti-seize on a few threads to insure easy removal in the future.Avoid removing a hot sparkplug if possible to lessen the chance of thread damage.
  • TerryK
  • TerryK's Avatar
05 Aug 2009 17:52
#311852
Never had a single problem with NGKs. I use nothing else.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • mzandmz
05 Aug 2009 18:58
#311863
Thank you
05 Aug 2009 20:43
#311882
I've been using Nippondenso ND W22ES-U plugs in my KZ650C1 and it seems to like them. Ed
  • PLUMMEN
  • PLUMMEN's Avatar
05 Aug 2009 20:49
#311889
ive always had good luck with b8s,but if its that cold out you might experiment with differant heat ranges to see if it helps any B)
  • bountyhunter
  • bountyhunter's Avatar
05 Aug 2009 21:37
#311905
The twins use the really hot plugs which is the B6ES or the W20ESU. The fours usually run the colder B8ES or the W24ESU because they get a lot hotter especially the inner cylinders. I know some people run the slightly colder B7ES in their twins for highway running to keep it cooler compared to the stock B6ES.
