rear signal lights
- krazinite2003
all the lights did work up untill a couple days ago i went to ride it to the store a couple days ago and found that the rear signal lights no longer work turn signal work but
well put it this way when i turn on the ignition on all lights should light up right well the head light will front signals will and tail light will but not the rear signal but if i use the turn signal switch both lights will blink i hope this makes sence fuses are fine was well
i have two 1983 kz750 L3
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- JMKZHI
- Thank you received: 48
The fronts serve as running lites & turn indicators.
- MFolks
- Thank you received: 540
- bountyhunter
- Thank you received: 337
True, at least in this state. I installed front units in the rear so I could use the rear turn signals for brake/running lights so I painted the lenses red to comply. Rear turn signals can be red or amber, but running lights in the rear have to be red.Most states do not allow rear running lights unless RED lenses are used.
Kawi did make some red lenses for the police bikes that fit the stock turn signals, but I don't know if they still sell them.
- MFolks
www.kandstech.com/index.php?page=Turnsignal
- krazinite2003
- krazinite2003
- roy-b-boy-b
- Thank you received: 103
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- bountyhunter
I have seen the red turn signal lenses for sale on ebay. I remember they were like $30 for a set of two. I looked the new OEM part price up on babbitts and it was like $6 each (they are the front lenses for the position lights on the cop bikes). Didn't try to order any, I just painted mine.My rear blinkers are red on both the 77 650 and the 76 900. Guess bro did that then. Don't look painted. He must have bought them somewhere. I'd guess e-bay. Not runnin' lights.
- bountyhunter
Ballpark of about a second, I think mine is 0.8 seconds so it will flash about 6 times in five seconds.oh and how fast are they suposed to flash
