Sorry if this post should have gone to a different category, but it is an electrical part...
Before I go and spend hours taking apart a lot of unnecessary stuff only to find there was an easy way... What's the easy way to remove the Regulator/Rectifier?
It seems to be fairly surrounded by frame pieces. Do you just remove the battery box from the top? Anything to watch out for? This is on an 82 KZ1000 CSR.
Thanks much,
Wes
82 KZ-1000 CSR
