Tachometer
- cblaho
03 Aug 2009 15:38 #311269
by cblaho
Tachometer was created by cblaho
I am loking for a Tach for my 82 KZ750H. Any help I can get will be great.
- MFolks
- Thank you received: 540
03 Aug 2009 15:47 #311272
by MFolks
Replied by MFolks on topic Tachometer
Try here:
www.redlinecycle.com
www.reproductiondecals.com
www.oldkawman.com
www.oldkaw.com
www.sudco.com
www.z-power.co.uk
www.zpower.com.au
www.oldkawman.com
www.oldkaw.com
www.sudco.com
www.z-power.co.uk
www.zpower.com.au
- JMKZHI
- Thank you received: 48
04 Aug 2009 06:07 #311472
by JMKZHI
Replied by JMKZHI on topic Tachometer
ebbaayy
- cblaho
05 Aug 2009 10:56 #311772
by cblaho
Replied by cblaho on topic Tachometer
will a tach from anouther model or size bike work for mine?
- JMKZHI
05 Aug 2009 14:27 - 05 Aug 2009 14:28 #311810
by JMKZHI
That's a poser. According to the cross-reference at Kawasaki.com, your bike is the only model w the exact same tachometer. However, I'd wager that one from the 81 or 83 Ltd-4 would work... There may be differences in the wiring for the various indicator lights, but the tach should work. Also, some meters have a voltmeter on them.
It's possible that one from a 750-Standard, 750-Ltd-Shaft or KZ650-CSR (maybe) would work. Again, these may have different wiring. The 650-CSR is similar to the 750H & has some of the same meter parts, including the same meter bracket.
Last edit: 05 Aug 2009 14:28 by JMKZHI.
