coil to plug order
- Summerheat
- Wanted at 17 Got it at 47 Worth The Wait!
coil to plug order
03 Aug 2009 07:53
Have read many post's that identify coil hookups are 1&4 and 2&3.
Is this physical 1 left cylinder and 4 far right cylinder and 2&3 being middle... 1,2,3,4
Or is this firing order 1,2,4,3 so physical cylinders 1&3 and 2&4
1976 KZ900-A4
- Mcdroid
- Gone Kwackers
Re: coil to plug order
03 Aug 2009 08:03
As you are sitting on the bike, look down and the far left cylinder is # 1...move to right to #2, #3, and #4 on far right.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
03 Aug 2009 09:30 - 03 Aug 2009 09:31
Summerheat wrote:
One of the coils is supposed to route its two plug wires to the outside sparkplugs which are numbered 1 and 4.
The other coil is supposed to route its two plug wires to the inside sparkplugs which are numbered 2 and 3.
On the large fours, typically the lefthand coil (on the bike's shift lever side) fires the outside plugs #1/4, and the righthand coil (on the bike's brake pedal side) fires the inside plugs #2/3.
I believe the KZ650 may reverse the physical coil positions, but never-the-less one coil fires #1/4 and the other fires #2/3.
Often, a black wire signals whichever coil is firing #1/4, and a green wire signals the other coil firng #2/3.
Good Luck!
Good Luck!
Last edit: 03 Aug 2009 09:31 by Patton.
- loudhvx
03 Aug 2009 09:35
Patton wrote:
Correct on the 650 coil positions. The 550, 650, and I would think the 750, have the 1-4 coil on the right, and 2-3 coil on the left.
Good Luck!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
