- Thank you received: 16
Installing dyna wires into dyna coils
- KZ250LTD
03 Aug 2009 00:33 #311080
by KZ250LTD
79 KZ1000ST
Past:
Many.
Installing dyna wires into dyna coils was created by KZ250LTD
I'm putting new 3.0 Ohm Dyna coils and wires on my 1000st and I'm not sure if the ends of the plug wires that are being installed into the coils need to be stripped first so that there is bare wire connecting or if a straight cut end will conduct the charge fine. Any help is appreciated!
79 KZ1000ST
Past:
Many.
- roy-b-boy-b
- Thank you received: 103
03 Aug 2009 01:12 #311087
by roy-b-boy-b
Replied by roy-b-boy-b on topic Installing dyna wires into dyna coils
I always strip about 3/4 inch and bend it up and then put on the end. Roy
- Old Man Rock
- Thank you received: 225
03 Aug 2009 04:01 #311098
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Installing dyna wires into dyna coils
Same here as Roy mentioned.... Strip, then bend up and back under the metal clip....
I guess it may also depend on the plug wires you're using... They should have provided you some instructions with the new wire set... Mine did anyways....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
