SPEEDOMETER ????????????????????????????
- oxcadillacxo
30 Jul 2009 19:13 #310463
by oxcadillacxo
78 Kz650 Sr
SPEEDOMETER ???????????????????????????? was created by oxcadillacxo
MY SPEEDOMETER DOES NOT WORK WHY NOT WHAT COULD IT B????:woohoo: :woohoo: :woohoo: :woohoo:
78 Kz650 Sr
- oxcadillacxo
30 Jul 2009 19:17 #310464
by oxcadillacxo
78 Kz650 Sr
Replied by oxcadillacxo on topic SPEEDOMETER ????????????????????????????
ALSO IN QUESTION MY LIGHTS NOT A WORK ON SPEEDOMETER I NOW MUST MEASURE SPEEDO BY SIGHT HAHA I UNHOOKED TURN SIGNALS COULD THEY HAVE BEEN WIRED TOGEATHER.
78 Kz650 Sr
- Old Man Rock
- Thank you received: 225
30 Jul 2009 19:19 #310465
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic SPEEDOMETER ????????????????????????????
Does not work which way?
Examples...
Speed is off..
Cable is turning but speedometer analog gauge is not turning...
Odometer is working but not analog speedometer needle...
Possibly broken cable based on questions above...
Possibly bad sending unit based on above....
We'll need a little more info...
OMR
Examples...
Speed is off..
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- oxcadillacxo
30 Jul 2009 20:36 #310480
by oxcadillacxo
78 Kz650 Sr
nothing is working odometer,speedometer, speedometer lights... They do nothing the only thing that works is my tach but i have no lights for it either but speedo does nothing !!!
78 Kz650 Sr
- bill_wilcox100
- Thank you received: 5
31 Jul 2009 00:41 - 31 Jul 2009 00:54 #310501
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic SPEEDOMETER ????????????????????????????
oxcadillacxo, IMHO there are two different and possibly unrelated fault symptoms being described above. Therefore, I see two different sets of troubleshooting procedures.
A---
Symptom: Speedometer does not indicate any speed...
Procedure:
1) Disconnect the speedometer cable assembly from the front wheel hub.
2) Rotate the wheel and observe the front wheel's cable drive unit.
3) If the drive unit does not rotate, be prepared to repair or replace the drive unit.
4) If the drive unit rotates then the unit is probably good and the speedometer cable assembly can be reconnected.
5) With the cable assembly reconnected to the front wheel hub next disconnect the cable assembly from the speedometer unit.
6) Rotate the front wheel and observe inner drive cable.
7) If the inner cable does not rotate, be prepared to replace the speedometer cable assembly.
If the inner cable rotates then the cable assembly is probably good.
9) Be prepared to repair or replace the speedometer assembly.
B---
Symptom: All instrument cluster lights are off...
Procedure:
1) All instrument lights are connected to the (-) Battery by the Black/Yellow wire circuit. Use a meter to check for continuity from an instrument cluster light bulb socket ground connection to the (-) Battery terminal.
2) If (-) Battery circuit is faulty be prepared to repair or replace the Black/Yellow wire circuit.
3) If (-) Battery circuit is good, use a meter to test the (I don't remember the colour code) (+) Battery wire circuit.
4) If (+) Battery circuit is faulty, be prepared to repair or replace this wire circuit.
5) If (+) Battery circuit is good, be prepared to test or replace all the instrument cluster lights.
5) If all the instrument cluster lights are good, be prepared to clean or repair the instrument cluster light bulb sockets.
That should be enough to get you started. Hope this helps.
Best of success.
Bill
PS
You may want to layoff the CAPS Lock... my ears are hurting and it’s not considered particularly friendly.
Thanks
Bill
A---
Procedure:
B---
Procedure:
Best of success.
Bill
PS
Thanks
Bill
Upgrades:
Montreal, Canada
Last edit: 31 Jul 2009 00:54 by bill_wilcox100.
- oxcadillacxo
31 Jul 2009 07:15 #310531
by oxcadillacxo
78 Kz650 Sr
thanks i will check all that out today !!! sorry for caps i was a little intoxicated !
78 Kz650 Sr
