Oil leak and now no electrical
- jbrewer73
30 Jul 2009 18:51 #310457
by jbrewer73
Oil leak and now no electrical was created by jbrewer73
I have an 83 KZ550. I parked it after cleaning the jets and riding and know oils was coming out of somewhere pretty good and now when I turn the key on no power. But all fuses are fine?? Thinking I the oil leak got something wet. Obviously have to fix whatever causing the leak but what do you think happened with the power.
Thanks in advance.
Thanks in advance.
- The Garbone
- User is Currently waiting for his bailout check..
30 Jul 2009 19:10 #310462
by The Garbone
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
Replied by The Garbone on topic Oil leak and now no electrical
Kill switch?
1979 KZ650 & Hack
1949 Ford 8n
- loudhvx
- Thank you received: 1616
31 Jul 2009 10:29 #310555
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Oil leak and now no electrical
Did you take off the tank? May have yanked a wire under it.
Did you mess with the airbox? Or do you even have an airbox?
If you accidently blocked the crankcase breather or knocked off it's connection to the airbox, then it might blw a little bit of oil over the top of the motor. If it's blocked, the oil will start blowing out of some of the engine seals.
I think we'd need some more details on where the oil leak is to help you out..
1981 KZ550 D1 gpz.
Other links.
- bill_wilcox100
- Thank you received: 5
31 Jul 2009 12:41 #310567
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Oil leak and now no electrical
Fuse holder clips sometimes look good and clean but do not conduct well. Clean well with fine wire brush. If problem persists be prepared to replace the fuse box... preferably the newer blade fuse type.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
