Stock points coils with electronic ignition?
- Cychotic
- No sir, I don't like it.
30 Jul 2009 01:22 #310305
by Cychotic
1977 KZ650 C1 with '78 C2 motor,
* OEM electronic ignition off '80 KZ750
* 4-into-1 header
* Uni Pod Filters
* #110 main jets, 17.5 pilot jets
1983 Honda V65 Magna stock...sold
1985 Kawasaki Ninja 600R project..sold
1997 Yamaha FZR600...latest toy
Stock points coils with electronic ignition? was created by Cychotic
My '77 KZ650 C1 with a '78 C2 motor has been upgraded with the electronic ignition off an '80 KZ750. It seems to work fine, but I'm wondering if the stock 4 ohm coils are compatible with the electronic iggy. Does anyone know if I can get by with the original coils, and if I need to replace them, how many ohms do I need?
* 4-into-1 header
* Uni Pod Filters
- loudhvx
- Thank you received: 1616
30 Jul 2009 06:37 - 30 Jul 2009 06:38 #310330
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Stock points coils with electronic ignition?
Cychotic wrote:
If it's the factory electronic ignition (as it says in your signature), generally they came with coils in the 2.5 to 2.7 ohm range. If it runs fine, don't worry about it.
The electronic ignition had slightly less dwell angle which means the coils will have slightly less time to charge than they did with the points. The lower resistance coils charge faster.
This will only be an issue in the higher RPM range. If you can reach redline at full throttle under load, then you are fine. If not, then you may want to look into Dyna or Accel 3-ohm coils, or some other 2.5 ohm coils.
1981 KZ550 D1 gpz.
Other links.
Last edit: 30 Jul 2009 06:38 by loudhvx.
- Cychotic
30 Jul 2009 14:21 #310403
by Cychotic
* 4-into-1 header
* Uni Pod Filters
Replied by Cychotic on topic Stock points coils with electronic ignition?
The bike hits redline just fine. Sounds like I should be ok with the stock coils. Thanks loudhvx, I was hoping you'd answer this one for me.
* 4-into-1 header
* Uni Pod Filters
