- Thank you received: 1
Finding parts for my speedometer
- toadson
28 Jul 2009 21:49 #309976
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Finding parts for my speedometer was created by toadson
Not sure if this is the right section of the forum for this, but I have a 79 KZ1000 LTD with the cable driven speedo and tach, and ever since I bought the thing there have been a few parts missing on the speedo. First off, I have no glass, so it is open to the elements which I am not too keen of. Second, I can't reset the tripodometer, because the knob you use to reset it on the bottom side of the speedo is gone. It's also very noisy when going down the highway, so the whole unit may need to be rebuilt anyway, but is there anywhere to get these type of parts? I thought someone used to restore the gauges on these bikes, but I don't know for sure. Any ideas?
- gane
28 Jul 2009 22:07 #309978
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Finding parts for my speedometer
T, with the exception of mounting hardware none of the pieces of either speedo or tach were offered, search for re-built/rebuilders. while not an owner, have seen pics of some i covet.G
- donthekawguy
- Thank you received: 8
28 Jul 2009 23:01 #309987
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Finding parts for my speedometer
Just get a set off ebay. Plug and play for cheap.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- roy-b-boy-b
- Thank you received: 103
29 Jul 2009 04:34 #310004
by roy-b-boy-b
Replied by roy-b-boy-b on topic Finding parts for my speedometer
There is a link on z1enterprises for Z-Resto. It's on the useful links page. Bob does great work. Roy
- Stu Podaso
29 Jul 2009 21:07 #310261
by Stu Podaso
1980 550 LTD
If it has boobs or wheels your going to have trouble with it.
Man Law
Replied by Stu Podaso on topic Finding parts for my speedometer
On my speedometer I replaced the trip meter knob with a lamp turn knob & extension.
It's not too difficult to take your meter apart.
Then you could see if you could help it with a light cleaning and oiling.
A local glass shop should be able to cut you a new glass.
Good luck!
Good luck!
1980 550 LTD
Man Law
- toadson
01 Aug 2009 23:32 #310862
by toadson
Replied by toadson on topic Finding parts for my speedometer
Stu Podaso wrote:
That sounds like a good way to fix it. Is there any certain type of knob I would need to get for it?
Good luck!
- Stu Podaso
20 Aug 2009 21:28 #315444
by Stu Podaso
1980 550 LTD
Man Law
Your local hardware store should have some table lamp parts that will work.
1980 550 LTD
Man Law
